Crimestopper RS-4G2
Crimestopper RS-4G2
I have tried to install this remote starter kit on my 2006 F-250 diesel XL model. This truck was just a basic truck. I installed a keyless entry system on it by crimestopper model# CS-865.RKE but removed it because the new system I thought would support keyless entry. Here is how I have it wired without the locks because I have no idea where they go or feed from. I need some help bad.
12 pin low current plug:
yellow white- not used
orange- not used
pink-was told this could not be used on my model it would have to be
programmed
gray-not used
purple-Brake Switch-connected to light green at brake pedal switch
green-Start Activation-unsure if needed
orange black- not used
white- hooked to parking light switch but does not flash
yellow black- run ignition-hooked to red and light green at ignition
switch harness
brown- not used
black-ground
red white- Tried to hook to tach wire which has a steady 12v at all rpm
but still no luck starting
6 pin high current plug:
2 red fused wires hooked to battery terminal
Pink and White- not used
Pink-hooked to wire only with ignition power source
Grey- A/C Heater Control Power
Brown-hooked to dark green from ignition harness and it reads 10v while
starting but still will not start
3 pin low current plug
Blue- not used
Red- Not used
Green- Not used
Also I am not sure what the other low current plug is for or if its
needed. Also do I have to reinstall the CS-865-RKE for the remote locks
or can this not be programmed for the new system. The box clicks as if it is trying to start but nothing else. I also tested all the prongs for the large 6 pin plugs and they all read as they should with the exception of the pink and white which is not hooked up. Please let me know if
the wiring is correct or not and where they need to go. Im stuck with the dash torn apart and no DIESEL TRUCK to drive and you know how that makes a man feel. Back in the 4x4 Jeep I guess
orange- not used
programmed
gray-not used
switch harness
brown- not used
black-ground
Blue- not used
Red- Not used
Green- Not used
OK so I have wired the unit up correctly per crimestopper but the truck will not start or even attempt to start. I have power at all the places I should and when I should but I cannot get the darn thing to work. I dont even think my remotes are programming properly but the lights flash when you lock or unlock, and the module clicks 3 times when you try to start the truck but no go. I purchased a 30amp relay just in case but am unsure of how to wire this thing up and what needs it the starter or the ignition wires. Any help would be greatly appreciated Im tired of this darn truck starter.
It's not even trying to start the truck. Horn works, parking lights come on when the start button is pressed but Im not getting power to the pink wire from the large 6 pin harness which is hooked to ignition #1. Pink and white does not have power either so I have power going into the module, good ground, but the box or whatever is not telling the pink nor pink and white wore to have power. Any clue on this?
I have to press my remote's start button twice before it works. But then it doesn't do the pre-crank routine unless I do and it sounds as if the OP's truck is doing everything but actually cranking.
Chris
Well any ideas someone mentioned uwing the 3 low current wires which are ign 2, start 2, and acc 2. If these are needed then where do they hook up? One guy said to move the pink and white to the glow plugs at the steering column and hook up one of Tue low current wires but never mentioned which one or where to hook it to. Any help is greatly appreciated.
whiteboyslo
17
08-04-2020 05:10 PM
97Fordf35089f250
20
12-31-2015 12:25 AM
mkoser
2004 - 2008 F150
13
09-23-2015 03:17 PM
