1957 F600 11-22.5 opinions
I was given 6 almost new 11-22.5 tires. My motivation for putting these on my 57 M&H is to lower the revs on the freeway since I was 6.80 gears in it. I drove the truck on my property today and could not make them rub.
Before I mount the rears, my question to you guys is, do they look good or do they look funny?
They look great. I personally would like the more radical tread pattern like on Chuck's truck, since it is a4x4.
I have a set of wheels that are 22.5s and wide....like 8-9'' I have not looked at them lately but have been wondering about tires on front of my 57 f600 as well.
Would these wide wheels accept narrow tires....like the narrower they are the easier to turn with no p.s.
Ya, my valance was cut for a crank driven water pump. I have seen two chrome grills. It's to bad there are no reproduction grills available for the 57's.
The earliest 22.5 wheels, dating back to 1956, were quite narrow at 5.25" and 6.00" and were spec'd for 7-22.5 and 8-22.5 tires respectively. Those narrow widths are today made in China, but are not imported or made here. Notice those two sizes are non-radial, because in the early years the wheel manufacturers voided warranties if radials were used.
Most newer wheel designs, on up to those currently being sold by Accuride, have been 6.75" wide. Those are spec'd for a 9R22.5, but are approved for the 10R22.5s. The narrowest 22.5 sold today is the 9R22.5.
A chrome grille was offered in '57 to my understanding. I have a good friend that just had his show chromed to the tone of $1300! Stu
Bill - I'd suggest looking at the width of your 6 lug tubeless 22.5s. The widest I find record of were two 7.50" Budd designs, one with greater offset than the other, that dated from the late 1970s. These were spec'd for a 10R22.5 tire but were approved for a 9R22.5 at the narrow end and an 11R22.5 on the wider side.
Hmmm, 7 inches? I'll wonder if you've got what they call the 7.50s. I'll come back and edit after I do a scan and post a diagram showing how they measure. From the look of the diagram they continue the width measurement for a short distance up the lips' curves. If you've got access to the back of the wheels, too, I can see if I can look up their numbers. If they're Budds they'll be on the concave side stamped in the metal along the drop center. Accuride puts the numbers on the face between lug holes. Stu
Yeah, that's to be expected I guess. K-H made them too, but the only numbers they put on wheels were on a paper tag on the inner wheel base. Not something that would last a long time. Also, I've seen K-H wheels that only had the National Wheel and Rim Association (NWRA) number on that paper tag. I've got NWRA catalogs and K-H catalogs up to 1990, but they don't cross refer part numbers to each other for some maddening reason. So, what I can say is that the only widths listed in any of the catalogs are the ones I listed above. So you've got either the 6.75" or 7.50". The above drawing is an industry standard diagram so it would apply to any brand of wheel. Stu
