391 ft heads on a 390
Ft heads will really choke up your RPM ability so it get really weak about 3500 or so rpm.
Although they could really do something in a rock crawler or something of the such where you high idle alot and need really snappy torque that a smaller head will help give. Kind of like the peanut ports Chevy used on there 454 in the 70's-80's trucks. Ford had the same thing on 460's.
But probily they would work quite the way you'd like, and stock truck FE castings with port matching, and exhaust polishing would be alot better.
You would need to use FT intake, and exhaust manifolds. The FT left-side manifold, I think, interferes with the motor mount perch (because FTs were installed using engine mounts on the timing cover and/or bellhousing, instead of on the side of the block).
Better to just use the 390 heads you have. They definitely flow better.
I have no part # to give . And i did this swap 20 yrs ago on a bet they said couldn't be done.If i recall i used the 331 flywheel that was smaller so it could fit the bellhousing of a FE engine to the motor. Because the 391 had a Clark 5 speed and the 435 wouldn't mate up to it. I had a pilot bushing made of silicon bronze to fit the back of the crank to accept the 435.The manifolds i bought off a u-haul dealer for i remember those 350 ford u-haul trucks had 331 md and hd motors in them and they bolted right up. ,for i needed them cause of the exhaust crossover.The drivers side looks like a y shape and the passenger side is a little diffrent from a standard 390 manifold.That is what i remembered . Oh ps i still have the truck.If you would like i could take some pictures.
mechmike360
24
08-20-2014 11:32 AM
jep9005
28
09-03-2013 10:18 AM
ling
07-01-2004 09:07 PM
