Mustang II on a 56. Pictures included.
Old 01-08-2011, 07:14 PM
BACAGrizz's Avatar
BACAGrizz
BACAGrizz is offline
This will be the beginning of the documentation of my conversion.
I started by draining the coolant and pulling the radiator.
Next was removing the bolts from each side of the fender to cab connections and the radiator support bolts. Once those were out I disconnected any wires going to the fender wells and clipped the headlight and parking light loom to splice back later. Then it was time to remove the entire front end in one piece.
Next was the front axle. 4 bolts later I was dragging it out from under the truck.
Anyone interested in a front axle for a 56 with good kingpins, nice brakes and drums, good hoses and good wheel cylinders? If so, PM me.
Not bad for an afternoon's work.
Next weekend I borrow a cherry picker to pull the engine and trans. Then the fun begins.
Old 01-08-2011, 08:01 PM
Old F1's Avatar
Old F1
Old F1 is online now
Good on ya mate! Full speed ahead.
Old 01-08-2011, 08:43 PM
pintoches's Avatar
pintoches
pintoches is offline
subscribing
Old 01-08-2011, 09:37 PM
tacson's Avatar
tacson
tacson is offline
Bumping for subscribing purposes
Old 01-09-2011, 09:22 AM
9teen56f100's Avatar
9teen56f100
9teen56f100 is offline
me too, Bump
Old 01-09-2011, 09:31 AM
Björn's Avatar
Björn
Björn is offline
here the same
but why is still the hood on
Old 01-09-2011, 09:49 AM
BACAGrizz's Avatar
BACAGrizz
Originally Posted by Björn
here the same
Didn't have to take it off to get to the frame. One less thing to worry about later.
Basically, I am too lazy to remove it if I don't have to.
Old 01-09-2011, 09:56 AM
Björn's Avatar
Björn
Björn is offline
I thought the hood will not open that far to get good by the bolts
Old 01-09-2011, 10:44 AM
hellfirejim's Avatar
hellfirejim
hellfirejim is offline
Bump for subscribing. It looks like you have a good start. thanks for effort in details and pictures. it is always good to learn.
jim
Old 01-09-2011, 11:50 AM
BACAGrizz's Avatar
BACAGrizz
Actually, the hood opened more far enough. There are only 2 bolts on each side that you get to from under the hood.
Then there are 4 here. The top three are from inside the cab and the bottom one is from inside the fenderwell.
Next are these three from inside the fenderwell.
Repeat on the passengers side then remove these 4 from the radiator support.
After that all you need is a helper to lift the fenders and grille off as a unit.
Old 01-09-2011, 12:41 PM
Björn's Avatar
Björn
Björn is offline
Great!!!!!!!!!!!! thanks
now i now with building the f that is first gonna put it together on the floor and then on the frame
Old 01-09-2011, 03:49 PM
Last Chance 56's Avatar
Last Chance 56
Last Chance 56 is offline
Go Sooners. What Mustang II unit are you putting in?
Old 01-09-2011, 04:52 PM
BACAGrizz's Avatar
BACAGrizz
The BACAGrizz Special:
Heidt's rod shop crossmember
Heidt's power rack with 4" extension kit..
Ride Tech upper and lower strong arm tubular control arms.
Ride Tech Shockwave 1000 master series, single adjustable, with internal sensors.
Wilwood Pro Spindles, stock ride height.
Wilwood Forged Dyna Lite disc brake with hub for pro spindle. (Front calipers are matched to existing rear brakes incorporating a little bit of bias to the brakes before even installing a proportioning valve.)
We'll see how it works out. On paper, it should all bolt together without issues and be perfect for my truck.
Old 01-09-2011, 08:31 PM
boss66's Avatar
boss66
boss66 is offline
Have you considered a 2003 up crown vic front end?
Old 01-09-2011, 09:07 PM
BACAGrizz's Avatar
BACAGrizz
Yes, I had. I also considered the Volare, Heidt's super ride II, Fatman, TCI, mid 80's Ford station wagon, Ford Granada, Camaro front clip, Nova front clip, Jaguar front and rear, etc... After three years of research and deliberation I came to the conclusion of the parts previously listed.
I've owned this truck since 1988. I have wanted to do something to the front end for almost that long too.
Quick Reply: Mustang II on a 56. Pictures included.
