Dead BII, '88 2.9L,5-speed, 4X4 - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > Bronco II
Reload this Page >
Bronco II Ford Bronco II
Old 01-29-2011, 08:23 PM
Eddiec1564
Eddiec1564 is offline
Eddiec1564 has a great reputation on FTE.Eddiec1564 has a great reputation on FTE.Eddiec1564 has a great reputation on FTE.Eddiec1564 has a great reputation on FTE.
Good to hear its running! Now its time to find and fix that leak before another ECU gets wet. I currently have my B2 down with another bad A4LD tranny and decided to go after the leaks it has. I took out the dash and the firewall is not a pretty sight. There is a rust hole right on top of the ECU location in the cowl area seam! Also the rain gutters will leak down the "A" piller and right on top of the ECU too.
Hopefully tax return will have enough $$$ to get that thing running!
Old 01-29-2011, 11:32 PM
DFWBII's Avatar
DFWBII
DFWBII is offline
DFWBII is gaining momentum as a positive member of FTE.DFWBII is gaining momentum as a positive member of FTE.
Well,, your right on that. it seems there was a big wad of leaves, straw and lint in the air return duct under there(for re-circulating air when the a/c is on. I had to cut the plastic grill out to clean it out. evidently water was laying in there and migrated down into the ecu wiring. Ill be sure to check the gutter area too,, thanks for the tip. my 5-spd, diffs. and trans case dont have any leaks but I'm going to drain em anyway and put in mercon like someone else said here. my 89 ranger stk used mercon too,, seems awful thin but,,ole Henry F. knows whats best,,haha. Larry
chrislang
Bronco II
18
02-17-2018 06:18 PM
BII Plow Truck
Bronco II
04-17-2009 10:12 AM
lockwoodx
15
08-04-2008 08:30 AM
techusition
Bronco II
11-15-2005 04:45 PM
88bii
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
09-25-2004 12:07 AM
Quick Reply: Dead BII, '88 2.9L,5-speed, 4X4
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
