HELP, SQUEALING SOUND WHEN SHIFTING GEARS
I have a 1996 Ford F-250HD 4x4 5.8 5 speed transmission. I had the clutch changed, flywheel turned new pilot bushing, new throwout bearing and new slave cylinder. Now when I start out and every gear change I get a squealing sound, let off the throttle and it eventually quits. Had truck back to mechanic who has replaced the throwout bearing and it still does it. He can not find the trouble. Has anyone else had this problem.
Thanks
Thanks
It wouldn't unless he had someone in the truck to push the clutch pedal down OR the problem was in the transmission. When the clutch pedal is up the pilot bearing(another possible suspect) would not be working as the input shaft of the transmission and the flywheel would all be turning together.
It would have to be a defective pilot bearing, a defective throwout bearing, or some sort of improper installation.
96F150-4.9
33
09-05-2020 11:04 PM
Newcomer
09-13-2011 07:24 PM
G2IC_Wraith
15
03-01-2004 03:31 PM
