'04 F150, I smell gas fumes when I let off the accelerator
I have an '04 f150 4x4 5.4L lariat new body style, I purchased it a few months ago. (I had an '03 f150 4x4 5.4L lariat that Im compairing the new one to) It seems like this 04 doesnt want to get up and go,(like the '03 did) best way to describe it is like having a potato stuck in the tail pipe. then after driving it for a few weeks I got CEL I think it was P0140, the day I was going to change bank 1&2 sensors 2, the code went away. so I didnt change them. I instead opted to change the plugs (all plugs came out fine) now I notice a fuel smell when I let off the accelerator,(not sure if I smelled it before) its like a boat exhaust smell- not a raw fuel smell. I am wondering if all these things add up to a clogged or partialy clogged cat or just a bad o2 sensor, I dont to spent $100+ for the rear two o2 sensors and still have the same problems, nor do I want to replace the cats and find out it was the o2 sensors all along. when I smell it in the cab, I do not smell it anywhere else, like: under the hood, or any where else under the truck, nor do I see a leak under the truck.
id also go with a loose spark plug.my dads truck had a bad gas smell under the hood and we found a loose plug.also had a cat melt down on it also a few months later.the top side of the brick looked ok.when i cut a square out of it in the middle the thing looked like a volcano.he was exsperiancing a major lose of power.it sounded like a 4 barrel carb getting the seconderies opened up.
drop the exhaust down and see if it runs better.i had a cat code for the side that was giving me problems
