Took truck to mechanic for oil change and replace fuel filters. He ran a scan on it and several codes one was P0611 FICM performance and 3 injector codes. Also found the sway control arm loose on the friont end
Theres a very good chance of it. Generally, you'll get contribution codes for all cylinders with the p0611. More testing should be done to verify the ficm though.
In the 6.0 forum there is a test and a fix for the ficm that you may try before getting a new one. You can reflow the solder joints and sometimes that fixes them. Worth a try and cheaper than a new one.
