Heater shuts off randomly
Old 01-04-2011, 11:55 AM
chanman17's Avatar
chanman17
chanman17 is offline
Hey hey FTE. My heater randomly shuts off in my '73 F350 390....any ideas why? It runs for about 5 min then shuts off. So I'll turn it off, then when I turn it on again it works for another 5 min. Not sure what's going on.....
Old 01-04-2011, 12:04 PM
DKW 86's Avatar
DKW 86
DKW 86 is offline
Fan or heat from the core?
Fan, could be the relay right under the glove box.
Heater core, could be a air bubble in the cooling system OR it could be the vacuum operated heater valve. Need to check the vacuum lines, especially the ones around or near the vacuum accumulator.
Old 01-04-2011, 12:06 PM
chanman17's Avatar
chanman17
Yeah, it's the fan. It just stops.
Old 01-04-2011, 09:23 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
There's no relay in this setup, just the speed switch, blower resistor, and motor. I'd check for power at the blower motor during the failure condition. If you have power at the motor when the fan should be ON yet the blower motor is not actually running, then this would indicate the blower motor should be replaced.
Old 01-04-2011, 09:32 PM
wasowski's Avatar
wasowski
wasowski is offline
maybe a new motor with a thermalcople? I know a/c motor have this but d/c.have to check on that
Old 01-04-2011, 09:54 PM
chanman17's Avatar
chanman17
What do you guys recommend for a repair manual?
Old 01-04-2011, 10:08 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
I recommend us....
and a close 2nd the factory service manual available in print and CD on eBay and elsewhere...
I would say your switch is overheating.
Josh
Old 01-04-2011, 10:09 PM
chanman17's Avatar
chanman17
I've learned everything I know so far from this forum. As a first time owner and hobbyist repair man, you guys have made me.
I'll take a look this weekend. Thanks!
Old 01-05-2011, 07:32 PM
wasowski's Avatar
wasowski
wasowski is offline
Originally Posted by Bullitt390
I recommend us....
Josh
I would say bullitt is right ,the switch contacts heat up and open because the bi-metal got weak,replace switch and/or find out why the switch is getting over worked like loose conntions or dirty contacts old blower ect.
AdamG238
07-01-2014 12:17 PM
IHblarp
Escape & Escape Hybrid
11-05-2013 07:38 PM
jthomast8
1999 to 2016 Super Duty
07-08-2011 08:06 AM
gearhead0211
11-05-2007 05:59 PM
Quick Reply: Heater shuts off randomly
