what engine did this exhaust manifold come off of?
Fits: 1968 Galaxie/LTD/Thunderbird 390 / 1968 Galaxie/LTD 428 (except Police Cruiser).
7L18 = Cast November 18, 1967.
The flange where the inlet pipe bolts on is in a different location for a passenger car than it is for a truck.
C6ME-AA = Engine block casting number, worthless for ID'ing what size the FE engine is. It could be a 352, 360, 390, 410 or 428. Casting numbers cannot be cross referenced to Ford part numbers
And, all FE engine blocks were originally cast as 352's, only when the blocks were finished, could they be another size.
7E27 = Bare block cast May 27, 1967.
7E26 = Head cast May 26, 1967.
ID number: C8AE-9430-A / Ford part number: C8AZ-9430-A .. Right Exhaust Manifold / Obsolete
F100/350 FE's used different right/left exhaiust manifolds than passenger car FE's.
This is the passenger side F100/350 manifold: DOTZ9430A (replaced C5TZ9430A) .. Right Exhaust Manifold / Obsolete
Fits: 1965/67 F100/350 352 & 1968/76 F100/350 360/390.
1965/67 352's use a different left exhaust manifold than 1968/72 360/390's, because '65/67's have a heat riser valve.
Either manifold will bolt on, but if you have a 1965/67, you won't be able to use the valve if using a 1968/76 manifold.
Fits all: 1958/76 332/352/360/361 (1958 Edsel only) /390/406/410/427/428 FE engines!
You cannot tell one size FE engine from another by lookin' at it.
Look on the #3 crank journal for a stamped ID number, post what it is.
You can measure the stroke, that'll pin it down somewhat / 352/360: 3.50" / 390: 3.78" / 410/428: 3.98"
Bore: 352: 4.00" / 360/390/410: 4.05" / 428: 4.13"
You're speaking of this: B8AZ6359A .. Crankshaft Damper Spacer.
