2003 crown victoria IFS install on a 1956 f100 frame ?
#32
#33
#35
From the F100s I have seen, they pretty much bolt in. If you want to go thru the extra work, others have been narrowing the CV IFS up to 5 inches and narrowing the frame as well to have a better wheel selection.
I have an F1 which is narrower than the F100s and I took out about 2.75" of the cradle, welded the cradle and Im in the process of narrowing the rack. The only frame mod was to cut the bottom of the rail to level it out to retain the flat surface so the CV IFS retains the proper caster angle.
#37
That looks the same as what I ended up with when using the c10 frame for my panel, however I was able to get new modular spindles that brought the wheel in 1 1/2" each side so now I don't have as much of an offset to look for. Like you I will have to go with a larger diameter rim to clear things. Your frame looks real nice.
I'm in the process of ordering wheels from Detroit steel but they need at least 4.5 clearance from hub to fender. Im a bit shy of 4 inches right now with the cv ifs on my 54 f100
#38
#39
Received 4,119 Likes
on
You mention modular spindles to gain 1.5 inches.. what exactly did you use? Part number or where can I find them?
#40
Contact a member
Not sure if a 56 is the same, but here is my 54 with one. They work really slick. Hope this helps. also i moved mine forward some, to center the wheel in the fender well Attachment 203162
thank you
#42
ETOWN55
53
11-21-2020 01:30 PM
fun4evrusa
01-11-2017 02:11 PM
