hello guys today my dad brought me home a 94 F-250 and i was wondering if i could clear 35x12x15in procomp x-terrians with only a 4 inch suspension lift and a 3in body its only a 2wd but ide like to make the best of it ...if not tell me what i need
I don't see why it won't. About the only other thing you may have to do is maybee trim the inside edge of the front bumper. I had 35-12.50 BFG mud TA's on my truck with no lift at all. I did move the front bumper out one inch and cut the inside corner off. You should have plenty of room. Good luck Hippie
Did you say you had no lift at all and fit 35's on your f150?:-staun
I just got the same truck. So, all I have to do is move the front bumper out and cut the ends? Is that really all?
Unfortunatly the rims are 16.5 x 9.5. When I was running 35x14.5 swampers I aired down to 12 psi on the dunes and blew the tire COMPLETELY off the rim. It rolled away actually. So stick with the 16's. The 16.5's were a steal so I got those instead of 16's.
