6.0 diesel - overfilled motoroil?
more than likely the white smoke is related to the Fuel Injection Control Module (FICM) or an injector that is experiencing what Ford calls Stiction (oil latching of the spool in the injectors). Make sure your batteries are both healthy and then look in the Tech Folder to find out how to check your FICM voltages.
For winter time I would recommend a 5W40 oil (Ford issued an update to include this as a recommended oil for -20*F to over 100*F). This and getting the latest flash updates to your trucks computer will help the possible stiction issue.
I only see the smoke when I crank it right away and don't let the glow plug warm up (which is rare) . Then it idles real rough for a few minutes until it warms up. This morning I made sure the glow plug was ready before I turned the engine over. It idled just a hair rough for about 2 minutes then purred like a kitten. But I'm going to look into that just the same. Here in Phoenix the coldest it's going to get is about right now, 34 degrees for the low, around 65 for the high. Lows usually in the 40's or higher this time of year. Highs around 116 in the summer (AZ desert ya know). So maybe 15-40 is ok? If not I'll go to the 5-40.
UPDATE: I changed my oil and it only took 13 qts this time to get the dipstick to read at the "max" level. I didn't change my filter this time (it's only been five days). Doubt it will change anything but will let you know. Thanks again for the support!
Normal - it is good.
I hear you on the temps for 15W40, but idling real rough (as you previously described) is not normal. I was starting up in 20*F weather recently w/ no block heater and only waiting about 5 seconds to crank. I had a little white smoke at first and then it went away, and no rough running. This is how it should be. Be aware that the glow plugs will run up to two minutes even if the wait-to-start light goes out.
Have you had your trucks processors reflashed in the last couple of years? If not, you could have stiction issues that have been developing since you bought the vehicle - even if you are not in extreme cold weather.
When I first crank it up in the morning it runs as if it's out of balance. Picture an oval crankshaft, it seems to run like it has an oval rotation to it. Only way to describe it, so sorry if that doesn't make sense. Then suddenly it warms up a little and the oval-wobble rough idle smooths out completely.
4x4countryboy
33
11-13-2022 04:37 PM
ryansalay
1999 to 2016 Super Duty
45
01-10-2018 06:55 AM
