Cold Starving? Empty float?
I have a 1984 F150/302/ automatic, when I cold start the engine after pumping twice, it will start right up, then run out of gas? have to restart again and again, Then keep the gas feathered in like a manual choke unit? should I suspect the choke? or do you think gas is leaking from the carb bowl? I do not smell gas at all.. after a few min. it runs fine, restarts fine when warm. I was told to buy a new carb? and if that is a recomendation here, what do you all think about a Barry Grant 525 4 barrel to replace the twin? thanks, for your help, vic P.S. she only has 36,400 miles, really! have already replace a lot of dry rotted hoses and belts...what a find!
Right on the money!!!!
You guy's were right on the money again, it was the choke adjustment, and a linkage was stuck. had that taken care of, and now she starts up easy, goes to fast idle, and if you want you could drive immediately. I also found that a tiny little spring in the ignition switch was causing the key not to return to the run position after starting? I guess the old spring just didn't have the push needed to do the job...I bought a NOS switch on e bay for 5.00, and had it put in, Happy happy happy!!! I was thinking of junking the carb, but now she down shifts nice when you put it to the floor. I don't know what I'd gain with a new carb? so I think I'll leave it stock. Now she looks good and runs even better! Thanks Guy's for All the help!, vic
Jeremy Kamutzki
12-11-2013 08:35 PM
94150
18
09-09-2013 02:01 AM
