Best Headers for 360 in F100
on
1 Post
Hey Kenny ! Good to see ya here and pokin around ! Happy New Years Bud !
I kind of think as I mentioned early in this post..just getting it to breath a little easier is cheap..and the best low dollar way to go.. But I'am still learnin about these motors..everyday something else suprise's me... Matter of fact I owe you an email..just been a hectic month is all... The very best to you and yours !!
Jo,
It's been my experience (to a degree), that individual engines get better fuel economy at different rpm on account of how they are set up.
With Bear's example of 13mpg with 3.73, you cannot discount him using a different top end. This probably pushed the torque peak higher..... His particular setup at 3,000rpms may have been more efficient than a stock setup with 3.00 gears at 2,400rpms.
Lugging an engine with 2.73 gears for instance just kill economy and the ole right foot becomes drastically more important.
Drew
Drew
Maybe if I put a 750 on it I could get 18.
John
and I do not recall a different top end just being a carb..... Bear's example was "heads, intake, exhaust, cam"
Having a engine built and matched to your application is more important that just one factor.
You have to remember my last piece of advice. With the 3.73 gear at 55 mph the motor turned just under 2700 rpm. Try running 60 mph at near 3000 rpm and you got 9 mpg. In fact anything over 2800 started loosing mpg in giant steps. The 13 mpg was with a bed canopy BTW, about 11.5 was the best it would do naked but living in the Pacific Northwest a open bed gets things wet to often and the truck was not a Kingcab, hell they only big cabs were by Dodge back then. Oh and the dist. was recurved.
MPG
410F
many years in Torrington still lots of family there and in Evanston.
My point is that regardless of what you do to the FE motors you will never and I repeat never get the money back through MPG improvement. You will not get more than 11 to 13 for any amount of money. But is fun to build them and to make them hungry to eat chibbies and to sound great but no matter how fast they may be, they will never pass a gas station. LOL
Russ;
Fun to lurk and not be heard but I couldn't pass this one as I have spent countless dollars chasing MPG with my 390 and the only thing that changes was the shape of my wallet.
UF
Russ;
UF
You believe what you want, I know what it did.
My second 1969 Torino Cobra notchback (but lighter by 400 pounds than the fastback and was a real race car and with a 11.5 to 1 with slightly cleaned up CJ heads, header, 4 speed close ratio toploader, 4.30's and a 406 3X2 set up and ram air ran 12.96 the first time down the track and ended up in the 12.20's at just over 120 mph after much tuning of the setup. Oh and it was quicker with the 3X2's than a 2X4 set up off a 427.
Big deal, I had a 1969 Torino Cobra Fastback with a ram air 428CJ, and C6 with both a 3.00 and a 4.30 rear end for it. With the ram air blocked open and the 3.00's in it it would get 13 at 70 mph. I wouldn't cruise it at 70 with the 4.30's as the motor was just about at 4000 RPM. But I didn't and don't run my trucks at 70 mph because I am more interested in the mpg (sic: money savings) that an extra hour or two at where I'm going. But again my 428CJ was a semi-race motor and not set up to MPG. A dual point no vacuum dist. and a rejetted carb (richer) did nothing to improve mpg, but the damn car was quick, in fact the only stock Mustang to ever beat it was a honest to God 427 single 4 barrel (never raced a 2X4 Mustang). The car ran 14.70 at 98 mph with the 3.00 using only 1st and 2nd. gears The 4.30's ran 13.06 at 102 mpg.
My point is these engines get a max MPG and no more. They don't really care what they are pushing around as long as you don't rev them past peak torque.
Oh and I probably know more about 428CJ's than you do.
#28
I guess I won't insult your intelligence any more by commenting.
#29
#30
