1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
1999 4R100 transmissiom oil
Old 12-29-2010, 07:35 PM
papp's Avatar
papp
papp is offline
Hi
I own a 1999 Motorhome on a Ford chassis. 4R100 trany and a V10 6.8l.I know the story of Mercon and MerconV debate . A few year back not to use MerconV in this trany and now a TSB came out and it was OK to use etc. I am planning to change the oil next spring and I am thinking of using Mobil 1 synthetic. Your thoughts Plaese. As far as I know this oil is compatible.
Thank you!
Old 12-29-2010, 08:26 PM
dkf's Avatar
dkf
dkf is offline
You'll be fine with M1 ATF. I would try to flush as much of the old fluid out of the system as possible. Use Mark K's method to change the ATF.
Specifications and Approvals
Mobil 1 Synthetic ATF has the following builder approvals: Allison C4
Mobil 1 Synthetic ATF meets or exceeds the requirements of: JASO 1-A and Ford Mercon V
Mobil 1 Synthetic ATF is recommended by ExxonMobil for use in applications requiring: GM Dexron IIIH, GM Dexron IIIG, GM Dexron IIE, GM Dexron IID, GM Dexron II, GM Dexron, Ford Mercon, Voith H55.6335.3X, MAN 339 V1, Volvo 97340 and Volvo 97341
Old 12-30-2010, 06:38 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,573 Likes on 1,051 Posts
This needs updating because it was written before Ford changed MERCON V to be compatible.
Mobil 1 synthetic ATF is my first choice.
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
Old 12-31-2010, 11:14 AM
papp's Avatar
papp
papp is offline
Thank you Mark and dkf. I will go with Mobil 1.
