cps or no??
cps or no??
Hey guys - truck started acting weird - sputtering like she was running out of fuel or something, so I thought there was water in the line, so I switched tanks - same problem. Put a tiny amount of methal hydrate in the tank. Next day, problem was gone, so I thought that was it. But, later it started again. She would run fine for a while, then the idle would jump up, CEL would come on, and she sounded like I just installed a racing cam (and she was faster too!). When I tried to hook up a friends scanner, she would stall, with no codes showing. After searching the various posts, I came up with cps problem. Bought one today at Ford (F4TZ-12K073-C) and installed it. She ran great at first, but then same problem. Anybody have any ideas??
Hey Copedawg - only does it at start-up? That's a good question. I guess the answer would be yes, but that's because I've never tried to drive it when it was doing this, so.... I can try and see if the mechanic down the street can read any codes (I try and avoid him because he charges me $30 each time!). What happens is that it starts normal, and then within a short time (say 5 minutes) it will start to idle rough, the CEL will come on, and the rpm jumps from 500 to 800. If I press on the throttle, she jumps ahead (like you would expect a gas car to do with a racing cam). So you don't think it's the CPS? Maybe I got a bad one??
How old is your oil?
Un-plug the ICP and start it....
Wonder if the IPR is sticking?
Also, being a 95 as I found out before I bought the AE scanner...Auto Zone / Oriely's scanners won't recognize the truck PCM.
Also read somewhere here that a CPS might or might not throw a CPS code...My recent CPS DID throw a code, but it would not start at all...
Since its throwing a code, the best line of attack is to figure out what the code is and go from there. For grins try unplugging the ICP sensor (front of the driver's side head) and see if it makes any difference.
Should also mention that I just replaced both UVCH's and all glow plugs (although this problem started before I did any of that). For what it's worth...
Hey everyone - thanks for all the thoughts. I can't go to Autozone or anyone like that because I'm in Canada, on a very small island, and there is no one like that around. My resources are limited. I should have also let you know that I just recently replaced both the ICP and IPR (within the last 2 months), and the oil was changed recently (I even changed the oil in the HPOP). Fuel filter is also pretty new (although I'll check that out tomorrow).
PS - nice truck, BTW
Ok, so this morning I checked the oil level. It's right on the full line, and still fairly clean looking (I'm running Rotella 10W30). Unplugged the ICP and started her up. She started normal, with CEL on, then after idling for 10 minutes she started again with the rough, high idle. I plugged the ICP back in, with no difference. I let her run for quite a while, then took her for a short spin. Again, no difference (although I still find it weird that she responds faster). Couldn't get the code checked, and the wife had plans for putting up Christmas lights, so I didn't get any further. I'll look at the fuel bowl tomorrow, and try to remove the IDM to see if it has water in it. Failing that, I'll try to get the mechanic to check any codes on Monday. Hate being without my truck....
Hey thanks - Black Betty's owner suggested the IDM - that there may be water in it, so I'm leaning that way....but I'll bite the bullet, pay the mechanic his $30.00, and get the codes scanned on Monday. I'll post the results. Thanks again! Michael.
Well, went to the mechanic this am. He can't get to read the codes until tomorrow. Here's the latest - she starts normal, and runs normal for the first 10 minutes or so. Then the CEL comes on and she runs real rough, rpm's increased, and is quite a bit faster when driven. Then, when she gets really warm (say, after driving for 15 minutes), she runs normal again. If I shut her off and re-start, she runs normal and the CEL is off. I wanted to remove the IDM and check for water, but we have a nor'easter coming and I don't have a garage, so that won't happen. Have to wait to read the codes tomorrow. Until then...
