Leaf Spring Problems
Old Dec 28, 2010 | 06:59 PM
TheRooster12's Avatar
TheRooster12
I was doing some work under my truck and noticed that two of the leaves in my driver side leaf spring are cracked... Was wondering if there is an easy fix or if there are compatible leaf springs from other years I could use? Thanks for the help!
Old Dec 28, 2010 | 09:29 PM
wyoming4x4's Avatar
wyoming4x4
leaf stuff
pm sent on leafsprings.
Old Dec 28, 2010 | 09:54 PM
Jigger2020's Avatar
Jigger2020
just replace the 2 broken leafs, its easy
Old Dec 30, 2010 | 10:23 AM
qman's Avatar
qman
I have the same problem. It looks like they're riveted in. How do I replace one and where do I get it?
Old Dec 30, 2010 | 10:49 AM
Jigger2020's Avatar
Jigger2020
look in your area for a spring shop, they are not expensive, if the one with the rivet is not broken you just pry the side of bracket out of the way
Old Dec 30, 2010 | 02:37 PM
qman's Avatar
qman
there is about a 2 inch section missing from one of mine and the remaining two pieces are riveted in.
is the solution the same thing - look for a spring shop?
Old Dec 30, 2010 | 03:53 PM
Jigger2020's Avatar
Jigger2020
yes replacing springs is about the same on all vehicles, as long as the main leaf is ok you can replace the broken ones right on the truck, you will need a good jack & some stands.
Old Dec 30, 2010 | 03:54 PM
Jigger2020's Avatar
Jigger2020
The main leaf is the one that has the bushing's on the front & the back
Old Dec 31, 2010 | 02:54 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Be aware that if your truck has Flex-O-Matic rear suspension, the leaf springs are different lengths than without.
Old Jan 4, 2011 | 10:00 AM
qman's Avatar
qman
Please clarify "leaf springs are different lengths."
I've never seen leaf springs where they were all the same.
Old Jan 4, 2011 | 10:06 AM
Jigger2020's Avatar
Jigger2020
let's say you a leaf spring for one wheel, in that set of steal spring's the main one is longest, the one under it is a little shorter, then the one under that is a little shorter & so on till you get to the helper spring which is flat
Old Jan 4, 2011 | 01:43 PM
NumberDummy
1965/72 F100 without Flex-O-Matic rear suspension: 24" > > eyebolt < < 28"
1968/72 F100 with Flex-O-Matic rear suspension: 24" > > eyebolt < < 32"
The additional length has to due to the Flex-O's compensator. The spring is longer to accomodate it.
For those that have never seen Flex-O-Matic, it's illustrated here: 1964/72 Ford Truck Parts Catalog / Illustration Section 55, Page 15.
Flex-O-Matic was also available on F250's.
Old Jan 4, 2011 | 04:31 PM
qman's Avatar
qman
Thanks dummy.
Illustrated where?
Old Jan 4, 2011 | 04:57 PM
NumberDummy
This catalog is available on a CD from hipoparts.com for around 22 bucks.
Old Jan 4, 2011 | 05:52 PM
qman's Avatar
qman
OK, I thought you tried to post a link but messed up.
I have the set of shop manuals at home. I'll just check it out there.
Again, thanks.
OFLM
Mar 9, 2015 08:24 AM
kioolt
Oct 25, 2013 05:12 PM
armyaviation
Oct 5, 2012 10:03 PM
shawn11762010
May 13, 2011 08:07 PM
clhart426
Sep 17, 2010 06:30 PM
