4X4 won't engage 2007 F150 XLT 5.4 SCREW
so its been cold out here and then it got warm one day so I washed my truck. now I'm having 4X4 problems, I don't know if washing the truck had anything to do with it. the 4X4 was working fine and then when I needed it, nothing no click, no light on hi or low. I checked all the fuses and I pulled the IWE but everything is checking out ok. anyone else having this problem? all I can find in a search is people saying that their hubs will lock while driving but that is not one of my symptoms. I did read that there is a motor on the transfer case that can get stuck. anyone having the same problems as me? any idea what to try next?
If you don't use it on a regular basis, the contacts can corrode. It's not so much the connector as the motor itself. On my 04, I've had this issue numerous times. Try to put into 4x4 low. Drive around a little and switch it out. Then try 4X4 Hi. Just need to get into the habit of switching into HI from time to time. This has worked for me so far. (Knocking on wood)....
OK, so let's go back and start with the basics. I don't have a pin out, but I would check to make sure you have voltage to the motor, maybe your switch is bad. If you have power, jump the motor directly to battery (this is where you need to know pins so you don't toast your motor) If you don't have power, than yes, check the fuses, check the switch. Look at your owners manual to see which fues/relays are for the 4x4. Sometimes the motor uses the chassis for a ground, so maybe that's why it's not working.. But I like to keep things simple and supply power directly to the motor.
same issue
hey, dextreme. i'm having the exact same issue. it got really warm and wet out and then froze again, and i also had to get my truck boosted. now it won't even attempt to engage. and i used it all the time, so i'm sure it's not ceased. checked all the fuses... all good. did you find the solution to your problem? it's been a while, so i'm guessing you have! i'd really appreciate it.
mybreathyourlung
34
08-14-2016 10:12 PM
New 2001 F250 Owner Here... Lot's Of Problems. 4x4 Won't Engage, No Cruise Control, Please Help!!!!!
wick001
1999 to 2016 Super Duty
04-21-2014 08:20 PM
ManicMike
11-12-2011 10:13 PM
