'56 throttle linkage kluge
I've got an "interesting" attempt to solve a linkage problem by the previous owner. The engine is 351W from what I was told is a 69 Mustang Mach I. I'm not exactly convinced of the exact donor but it is a 351W circa 69. The tranny mated to the donor bell housing is a 3sp from a what looks to be a passenger car. The carb is a Holley 2BL 2300 500 CFM model , manual choke. The stock linkage pictured in the exploded illustration seems to have a spring attached to the firewall and a couple of linked connecting rods to the passenger side of the engine. The problem is the current linkage kluge binds and sticks and defies adjustment making for inconsistent idling and starting problems. I'm hoping due to the popularity of the block and the carb model that someone has run into a similar problem and solved it with a better fabrication or even better an after market solution.
I went to Lokar and got their floor mounted pedal set up. what this does is cause the new throttle cable that you would need to buy to pull the linkage correctly. I then fabbed up a throttle linkage bracket and mounted it to the intake. total cost was about 80 bucks or so. I had it all built in about an hour. I'm not too sure how to attach a picture but I do have a couple.
FrankGRUN
07-10-2016 02:25 AM
FrankGRUN
04-10-2016 02:27 PM
shaker666
04-05-2016 02:52 PM
crazed87bronco
01-05-2012 04:45 PM
SonofaFord
06-05-2011 04:04 PM
