rebuilding my 5.4 for performance
Okay here is the scoop. I am new to this forum but I was told this was one if not the beat for information. I am rebuilding my 5.4 for performance so I am needing some help. I am not rich in information on the modular engines. I am looking for a good parts list that will give me torque and horse power, but I also want a pretty choppy cam also. I would greatly appreciate it if someone could help me out.
So its an NPI 5.4, (ford improved the design of their heads starting 1999 and they called them Power improved heads or PI heads).
You will need to go supercharged to achieve those numbers and b street able.
You will need a forged rotating assembly such as 5.4 2V/3V/4V RACING Rotating Assembly
Get some PI heads and cams: This guy knows his stuff: Modularheadshop - MHS and a good supercharger.
You could go hunting for used eaton lightning supercharger or even an entire lightning engine or look for a good used procharger.
You should research what you want, theres thousands of ways you could go with your engine. Try and search for threads on builds and results so you can get a idea of what to expect and familiarize more with modular before beginning anything. These engines are really expensive and hard to work on.
