Bike rack for bed?
I just lash our three bikes to each other with bungees and use cam-lock straps to anchor the whole thing to each of the four corners of the bed. I bought some foam pipe insulation to put on the bike parts that would rub. I've put hundreds of miles on this setup with no problem. Much cheaper!
If you want a cleaner install. Go to the local bike shop and you can pick up the quick latch mounts for your front tires. Then take a 1x4 and cut to the width of your bed. Bolt the mounts to the board and you are all set. I did this for my ranger and used it to travel half way across the country twice. I just recently bought a new board for my 150. It works really good and I think it cost me less than $20.
Good luck
chad
Good luck
chad
I assumed you were talking about pedal bikes correct? If so, the quick latch mount has 4 holes and you drill completly through the wood and use and actual nut and bolt not screws. If you are talking pedal bikes you would probably have to get into and accident for the bikes to move. When I talked about cutting the board to the bed width. You cut it so that it fits really snug, kinda like use a mallet to tap it down into place. Hope this helps. If you are talking about motorcycles then my idea isn't going to work in the slightest.
I went with the "just strap it in" method for a few reasons: 1 - not all of my bikes have quick-release front wheels. 2 - No storage issues when you aren't trucking the bikes - throw the straps & bungees anywhere, and use them for other purposes. 3 - Strapping the bikes tight to each other takes up less space in the bed than any multi-bike holder I've ever seen. 4 - no loose wheels to store & the bikes are ready to go when I get there. 5 - rubber tires are all that touches the bed - no scrapes, scuffs, etc in the paint (I put the kickstands up).
I alternate the bikes nose-to-tail and run straps from the "front" end of the frames of "the bunch" to the front of hooks on the bed, and run straps from the "rear" end of "the bunch" to the rear hooks on the bed. Pull all the straps down tight and nothing moves. I thought I had a picture of it, but I don't - but I expect you can picture it in your mind.
I have a front receiver on my Explorer that I put a cargo platform on, and I carry the three bikes up there the same way when I'm pulling our camper, except I tie the bunch down with bungees and straps due to the different configuration.
truck bed bike racks
Yakima makes good products. Pricey, maybe, but if you browse around their site, you may get some "do it yourself " ideas for mounting your bikes..... Good luck.
Larry in SF, CA http://www.yakima.com/home.html
I did the same thing as leiterch, except I used a 2x4, covered it in heavy felt (dark grey), and used screws since I was anchoring into a thicker board. It looks nice, is easy to take in and out, and is tons cheaper than a Yakima-style rack. I had plenty of comments from other folks who thought it very clever, and were a little sorry they spent so much on their pricey rack. I used to to the bungy thing, too, but this is much more secure, and taking the bikes in and out is also much quicker.
Wow! You guys have some great ideas. I work as a millwright at Ford. We do a lot of steel fabrication and construction work (we tend to build everything extra heavy duty, lol) I was considering building a bed back rack out of steel pipe. I was concerned about the overal weight of a 4 bike rack. I thought it would be a pain wrestling a heavy rack in and out of the truck.
All of your ideas were less expensive and less time consuming (cutting steel pippe & wielding) than mine. The PVC plan looks cool.
I use the RempRack (http://www.remprack.com) -- unique and different. Probably not for everyone. It's a bit pricey!
