Sponsored by: Real Truck
Looking for milage!
Old Dec 25, 2010 | 10:55 AM
RAHRAH's Avatar
RAHRAH
Looking for milage!
Hey Guys, Ive got me a 2000 f350 PSD 4x4 dually w 4.10s!!!! Yes I must say it likes to pull, what Im looking for is a way to cruise down the highway easier. Currently, its got 235/85/16s and its time for some new tires... I like the thought of the 19.5s but Im not looking for an extensive lift job. Im alright with the 16's but it is time for new tires. Mpg on the highway is were its suffering the most. I did recently add a programmer and 4inch ex and boy am I thrilled w those results! If only the next mods will be as wonderful as these! Being able to get 150k out of some tires would be awesome! MPG is what Im looking for tho. Thanks for the suggestions guys and Merry Christmas!
Old Dec 25, 2010 | 01:13 PM
fuelman's Avatar
fuelman
Which engine? Assuming a7.3l. If you get much bigger than 285s you will suffer mileage. When researching your next tires look at the tire weight of the various choices. The heavier the tire the bigger the loss. The wider the tire the bigger the loss. are you considering new wheels??
Old Dec 25, 2010 | 01:20 PM
bucyrus495's Avatar
bucyrus495
19.5 should fit thicker sidewall thicker bead and a dam tough tire Im sure you know but youll have to buy rims also toyo 16 pr makes a dam good A/T 19.5
Old Dec 25, 2010 | 02:09 PM
RAHRAH's Avatar
RAHRAH
Yes Im considering new wheels but at 2200 rpm at 70mph I really wasnt thinking that weight was the issue. yep its a 7.3. All my buddies certainly get better milage with their 7.3s. I was looking for alternatives instead of having to do 3.73s front and rear.
Old Dec 25, 2010 | 02:34 PM
jc8825's Avatar
jc8825
Lower gear ratios will hurt your mileage. The 4.10s are great for pulling, but not so much for highway cruising. Just drop the speed down to 60, which should bring your RPMs to about 1900. That will help.
Old Dec 25, 2010 | 02:56 PM
orng1's Avatar
orng1
I was going to say the same thing. Lower your speed. I drive a hair above 60 and get great milleage. I'm usually in the right lane though...
Old Dec 25, 2010 | 03:21 PM
Layson's Avatar
Layson
I would think a bigger set of tires will give you better mileage with that gear ratio....
Old Dec 25, 2010 | 05:01 PM
RAHRAH's Avatar
RAHRAH
I was hoping the bigger tires would help.... i guess im looking for more spped to!lol Id like to be able to do at least 70 comfortably and get some milage doing it!!!
Old Dec 26, 2010 | 10:04 AM
RAHRAH's Avatar
RAHRAH
After seeing that some M55 255/85/16s are around 1500$ before they get installed, Im thinking I do need to be looking towards some 19.5s
Old Mar 6, 2011 | 11:08 AM
RAHRAH's Avatar
RAHRAH
I ran into a huge problem. The trucks got 4.56 gears! Im just looking for better milage! still wondering what my options are
kas83
Modular V10 (6.8l)
Jul 18, 2012 09:35 AM
ArneJ
2009 - 2014 F150
May 23, 2012 09:19 AM
6CylBill
20
Sep 27, 2008 06:28 PM
Kapper44
21
May 14, 2008 08:39 PM
