Oil Cooler Gaskets
I reused the fuel line orings to there easy to get to if you find that you need to change one if it gets messed up
Intakes are reusable to if they dont get Jacked up coming out
you should get a turbo hardware kit remember to use antiseize on those turbo mount bolts I left the back bolt Off since it was a PIA to get out but the oil supply gasket on the top of the turbo does have alittle crush factor to it
and it helps to spread antiseize on the Exhaust Marmon clamps when you go to put the turbo back in alittle slip-n-slide goes along ways
Just remeber to Keep it CLEAN cant stress that enough that IPR screen clogs really easy
heres some pics notice how I stuck the turbo drain tube back in while I cleaned the valley and when I pulled the oil cooler out to help keep the junk out the HPOSystem
Ford Truck Enthusiasts Forums - BLADE35's Albums
Thanks for the info guys. I bought the turbo hardware kit, blue spring regulator kit and upgraded turbo drain also. I found some Never Seez nickel 2400 degree anti-sieze at an industrial supply house.
I hear ya on the IPR. I had to replace one last year because it was sticking.
Benny, it looks like you didn't have to remove your FICM?
My son and I were out in the shop just now cleaning off the bench getting ready for this weekend!
Jays_Truck
11-15-2014 08:42 AM
