Did the Econoline ever come with a manual transmission?
Old 12-22-2010, 08:00 AM
EconolineFan's Avatar
EconolineFan
EconolineFan is offline
I know back in the 80's and early 90's my dad had a a face lifted 3nd generation Econoline van with a three speed manual transmission I'm trying to figure out if it was the factory tranny or a conversion? If factory how common are they?
Old 12-23-2010, 01:10 PM
jimbbski's Avatar
jimbbski
jimbbski is offline
I don't know what years or engines had a manual available but my brother-in-law bought a new E-150 club wagon van back in the early 80's with a 302 & 3+1 manual trans. The trans started out as a 3 speed with a overdrive 4th gear added on. With a normal load it was fun to drive. It even would tow a light trailer with a boat.
The only problem he had was he didn't know how to back his boat into the water or pull it out without slipping the clutch. The OEM lasted 60K miles but the next two clutch discs each lasted less then a year. Finally we put in one of those "puck" type discs which he couldn't burn up if he tried. The only problem was it engaged like a switch, either on or off.
Changing clutchs on a van is so easy since you have such great access to the nuts & bolts. What you can't reach from below you get from above.
Old 12-23-2010, 08:21 PM
EconolineFan
Yeah I remember my dad was always replacing the clutch on that thing especially if he let someone drive it, lol.
Old 12-23-2010, 08:51 PM
fordman75's Avatar
fordman75
fordman75 is offline
I had a 78 E150 shorty van that had a 351W with a 4spd in it ( 3 + OD ) . I bought it with a fried clutch. It was pretty fast and fun to drive!
I'm wanting to swap a manual transmission into my current 96 E250. But I having a feeling finding the correct pedals may be a problem. I've never seen a 92 or newer with a manual transmission.
Old 12-23-2010, 10:09 PM
Henry10s's Avatar
Henry10s
Henry10s is offline
Yep -- '91 was the last year Econolines came with a manual transmission. Ford introed a redesigned Econoline in 1992.
Old 12-24-2010, 01:00 AM
fordman75's Avatar
fordman75
I have heard of a few 92+ Fullsize Ford vans with manual transmissions but they were Quigley 4x4 conversions. So I don't know what they did for the pedals. They are probably a custom pieces.
I tow a car trailer with my van. My 5.8L has plenty of power but I absolutely hate towing with automatics. So when my E4OD craps out I'm going to swap in a NP435. But I'll have to figure out something for the clutch pedal.
Old 12-27-2010, 06:13 PM
turbogus's Avatar
turbogus
turbogus is offline
"The Oven" my '81 Black Panel Econoline came with that 3+1 OD Trans. It's called a RUG-RAB by Ford. Aamco took two tries to rebuild this tranny and had to update the shifter linkage with a Hurst unit.
Old 12-29-2010, 09:35 AM
hillbilly469's Avatar
hillbilly469
hillbilly469 is offline
I had a 76 and a 79 with a 3 on the tree, the 76 I still have. The 79 always had trouble with the tube lickage in the column, the previous owner didn't know how to shift and just rammed the gears, I eventually put in a floor shifter. It had over 150,000 miles on the factory clutch when I changed it. The 76 has almost 400,000 miles on it now and its only had 2 replacement clutches in its life time.
I had a 86 with a 4 on the floor...well 3 with over drive but shifted like a 4. We got almost 180,000 out of the clutch on that one. I loved the stick shift vans personally but then I live in wv where its up hill where ever you go so it was nice to be able to shift when you wanted without the aggrivating gear hunting of an auto.
Old 01-01-2011, 09:01 PM
WilleyB's Avatar
WilleyB
WilleyB is offline
Strange I had a new 75 E150, 451 Windsor V8 with a 3 speed manual. I put a bumper hitch on the front for convenience when launching my boat.
Sold it with 110K miles on it no drive train problems at all, like the energizer bunny it just kept goin and goin
Cheers
Willey
Old 01-01-2011, 09:13 PM
fordman75's Avatar
fordman75
Cheers
Willey
Isn't a 75 older then a 91?
Old 01-01-2011, 10:02 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
The OD trans were 4 speeds, no "added on" OD.
Three speeds were available too. Three with an OD on the tail--maybe in the '60s early '70s.
Old 01-02-2011, 04:05 PM
turbogus's Avatar
turbogus
turbogus is offline
Years before I got "The Oven" ('93) I had a little shorty '66 Econoline window van. I always liked the look of the front ends on those and for $100, I had a mobile vehicle to keep some of my other parts in that wouldn't be an eyesore to my neighbors. It had a three on the tree with that spindly linkage and I was lucky to live in a harbor town Toledo, OR. with shops that'd stock odd bearings, bossed flanges and so forth, so was able to firm up the shift considerably after tracking down a correct sized bushing.
Another detractor of this old '66 besides being a window van was the P.O. had painted it with traffic yellow, so bright that I got a call from the ISS that they wanted to use it as a land based beacon. No losing THAT van in a parking lot.
The real concern was a terrible constant knocking in the bottom end. The motor would be turn key start up, rev up fine and run out to 60 mph, but I used it mainly for storage. I later saved up enough kazooks to get a 170 out of a '70's Maverick, whose shape matched the externals of the 140 residing in this '66.
Had a friend 70 miles distant that had a barn to do the transplant, so I motored out to Tangent OR. clattering all the way, a sound that I had become accustomed to. He wasn't home when I arrived so parked it in front of the barn doors until the following weekend when I could have at it.
Returning the next weekend, with my friend to unlock the barn, I fired up the van and started backing into the shop area when all of a sudden the motor knock ceased.
The motor was still running as I was backing, so brought 'er in and shut 'er down.
Peering out the windshield, I noticed a part laying in a puddle of oil, witha thin trail of oil running towards the front of the van. I walked out and picked up the part and saw that it was THREE LOBES OF THE CAMSHAFT that had broken loose, two intakes and an exhaust lobe! had found its way down the engine to the crankcase. Looking at my oil pan it looked like the old Ball Park franks televison commercial, "plumps when ya cook 'em" the pan had several golf ball sized dents along its length, save for the gash that a counter balance lobe of the crank finally defeated the oil pan.
Returning to the van and turning the key, she fired right up again, with what residual oil was left in the bearings.
After all was said and done I considered getting one of those vanity plates ~ "TIMEX"
Old 01-02-2011, 09:23 PM
WilleyB's Avatar
WilleyB
WilleyB is offline
Red face
Must have been one of those senior's moments for me I guess
Ah! Well life in one's 70's
Cheers
Willey
Old 01-03-2011, 09:18 AM
turbogus's Avatar
turbogus
turbogus is offline
Maybe the '75 was a newer aquisition?
Old 01-03-2011, 09:42 AM
WilleyB's Avatar
WilleyB
WilleyB is offline
Nope! bought it new in 75 along with a new Maverick 302 with a std tranny now if you wanted a wild ride in those times that was the way to go
Cheers
Willey
Quick Reply: Did the Econoline ever come with a manual transmission?
