Single barrel troubles
Old Dec 21, 2010 | 05:28 PM
Adams77's Avatar
Adams77
I searched but did not have any luck, so here goes...
My 300 cranks fine and will rev up but it dies if I give it a little throttle. I can push past and it will rev up but it always wants to die as soon as I open the throttle.
I cleaned and rebuilt the carburetor but had questions about the accelerator pump, it does not seem to squirt immediately like it should. Is this the problem and how do I fix it?
Old Dec 21, 2010 | 11:04 PM
4x4 Bart's Avatar
4x4 Bart
This sure sounds like the accelerator pump. It should pump near instantly. These carbs have a very tiny hose on the pump that can get kinked, also the diaphragm must be seated correctly for it to work right.
The metering rod must be at least one turn off its seat (That's clockwise open one turn, weird like left hand threads)
Old Dec 22, 2010 | 06:45 AM
Adams77's Avatar
Adams77
So the adjusting screw for the metering rod should be seated or a gap?
midd66
Jun 12, 2013 11:50 AM
LSO1123
Aug 25, 2011 10:47 AM
jal13232003
1997 - 2003 F150
Jul 8, 2011 09:29 PM
mabc926
21
Nov 9, 2010 07:45 PM
rangermann17
Apr 8, 2009 04:48 PM
