RPM-Speed Relationship
I put in the spare tach senor I took off a truck at the salvage yard since my old one wasn't working, and had a question on the RPM's. At 60mph its reading at 2700 RPM, which seems really high to me, considering the truck has 3:55 gears, even with the C6. Could the sensor be off and give a bad reading, or is this right? Any thoughts?
on
a trans without overdrive today will kill ya at the pump.
you may want to look into gear venders,E40D w/pcm,or zf5 speed.
over time,you'll save $ if you plan to keep the truck around for any length of time,and drive often.
id drive a max of 40 mph if i had a 3 speed before i gave my $ to the oil co. not kidding either.
Im going to be converting to a zf5 and 4x4 in the spring, as long as I can find a donor truck with all the necessary parts. I hate having to piece together a project. That doesnt help me now, having to drive the truck cross country sometime this week, guess I'll just have to slow down as much as it'll kill me
My motorhome witch I do nothing but highway driving with hours and hours non stop has 3.54 and the 3 speed C6 and I love it that way! 2600RPM sounds about right judging from the sound of it when cruising @ 60mph. Gets ~11-13mpg depending on condition. On the coast of California this summer cruising at 100km/h (62mph) I got 14mpg out of it! 14mpg with a cottage on wheels! I run on 6, 215/85R16 tires inflated at 70psi for maximum fuel economy.
But for my application, I preffer NOT having OD for a non turbo motorhome, being...well a box on wheels, has a lot of wind drag, so keeping the engine revving up all the time is a good thing, it's not lugging, always has power on command, and it's the best automatic transmission Ford EVER made! So no worries about some silly sensors going bad and damaging the trans. when i'm at the other side of the country....
Plus nothing compares to the highway Roar of an IDI
Would that chart apply to my truck? I'm running an automatic with the e40d, and 235/85/16's, I believe 3.55's and at 60 mph's with the OD on the rpm's sit at like 1500-1600 rpms. I can't get it any higher than 50 mph with the OD off, the engine is revving like hell at about like 1800 rpms but won't go faster.
on
im interested in your problem,but can't make out what your saying really.
did you intend to say;
OD ON = 1500/1600 rpms @ 60 MPH
OD OFF (3rd gear.direct drive 1:1) = 2800 rpm @60 and feels like your hitting the governor?
if this is so,
why would you want to drive faster than 45/50 in direct drive anyway? because your towing or?
you can tow in OD unless she starts searching back and forth between 3/4.i don't share this problem with the 3.55's and shorter tires.i just let her find 3rd on the inclines and revert back to 4th when she wants at the top.
can you word this entire statement in a different way please?
if this is so,
if this is so,
Even when I had the box filled with like 2500lb's, and a 6000lb trailer, punching it up steep hills in first gear going like 15-20km/h the rpm's barely touched 2000, and she was talking back on the quiet island road quite a bit.
