Crankshaft Pulley 5.8 vs. 5.0
Old 12-20-2010, 12:36 PM
93_flareside's Avatar
93_flareside
93_flareside is offline
I have a slight problem, my crankshaft pulley is wobbling. I've checked the bolts, and the harmonic balancer, all is fine. I've been looking for a pulley to replace it with, and haven't had much luck finding a stock one. Well, not had any luck finding a stock one for less than a underdrive set.
Here is my question- I've decided to put a set of underdrive pulleys on, and have found there are not very many sets for the 5.8l truck. Is the 5.0 crankshaft pulley the same size of the 5.8? And, will an underdrive set for a 5.0 work on a 5.8? Has anyone done this?
Old 12-20-2010, 12:43 PM
jk89cat's Avatar
jk89cat
jk89cat is offline
short answer yes, you can use the 5.0 pulleys , however underdrives are not usually a good idea on trucks , due to charging and cooling needs , especially if you tow!
Old 12-20-2010, 01:31 PM
93_flareside
Thanks for the input.
I have an e-fan and an overdrive pulley on the alt. Probally what causes it to go out every 2 years or so.
Old 12-20-2010, 02:16 PM
93_flareside
anybody know where I can get just a crank pulley?
Badmoonreizen
18
04-20-2016 06:34 PM
Jly154
10-22-2015 10:50 PM
Toplait
01-12-2015 04:01 AM
lil-red-f150
01-06-2015 10:16 AM
jrroth
2004 - 2008 F150
04-30-2012 12:21 AM
Quick Reply: Crankshaft Pulley 5.8 vs. 5.0
