Stock 4.6 needs mods for better Fuel Mileage - Page 3 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Reload this Page >
  #31
Old 05-25-2016, 11:45 PM
blupupher's Avatar
blupupher
blupupher is offline
blupupher is starting off with a positive reputation.
Originally Posted by firewize View Post
My real truck is 87 f250 4x4 6.9 stock with dump bed being rebuilt so bought 97 f150 4x4 4.6 w/flow master and k&n intake, returned to ford OEM exhaust and intake, shocked that mpg rose by 1.25.
I do agree flow master sounds nice but not worth it.
If you want mileage go diesel my 87 gets 19-22 mpg loaded gvw 10,000 lbs empty 22-24
Why did you bump a 6 1/2 year old thread?
I applaud you for using the search, but come on.
  #32
Old 08-10-2016, 10:17 PM
Danny01Expo
Danny01Expo is offline
Danny01Expo is starting off with a positive reputation.
surprised no one mentioned... Taller tires should give you better MPG as long as you don't get them wider with more resistance.. that's physics.. Now if you can notice or not, is the question.. but still.. if you've got to replace your tires anyway and they cost the same.. why not do it?
watch your RPMS and find your optimal cruising speed. it's usually around 49 to 53 mph where you're in the highest gear and the lowest rpm that is enough to keep you moving along...
and like someone else said, anticipate your stops.. and the lights that will turn green.. and the traffic.. see brake lights ahead? stop accelerating duh
and you might want to get a cheap ebay OBDII reader bluetooth and run an ap. last i checked they were $7 last year? might be even cheaper now.
  #33
Old 08-13-2016, 09:46 AM
Sycoholic's Avatar
Sycoholic
Sycoholic is offline
Sycoholic is starting off with a positive reputation.
I've done it all. Intake. Exhaust. Spacer. Tonneau cover. Chip. Nothing made a difference. Driving habits is the only thing that does. I've owned mine since 99 so I have some experience at this.
  #34
Old 08-13-2016, 11:30 AM
YoGeorge
YoGeorge is offline
YoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud of
Yo Danny...Unless the vehicle is geared too tight (like a 4.10 with no OD), larger diameter tires will reduce gas mileage because the engine will lug. And larger diameter tires, IF you can find narrow ones, weigh more and will reduce gas mileage because the engine needs to accelerate more rolling weight.
The concept of physics does not apply in a complex case like this. A lugging engine is not efficient.
Keep the engine tuned and drive for mileage. The 4.6 is an excellent engine for gas mileage IF it's not lugging. I know this from experience.
  #35
Old 08-13-2016, 10:57 PM
Danny01Expo
I disagree. The weight of the tire is negligible.
A body in motion tends to stay in motion.
Physics always applies. LOL
With taller tires you're covering more distance per axle revolution.
As far as "lugging engine" that might only apply at accelleration,
where MPG comes is at top gear cruising speed at the lowest possible RPMs.
with taller tires, you get better MPG wether you are capable of noticing or not,
assuming your'e doing highway driving, which you'd want to do for better MPG anyway.
  #36
Old 08-13-2016, 11:01 PM
Danny01Expo
BTW i just picked up a 99 F150 with a LEER hi top shell..
but i also scored a folding tonnea cover..
I'm wondering which one is best aerodynamically.. and i'm not sure why though, i want to get rid of the hi top and use the cover regardless. looks cooler IMO LOL
  #37
Old 08-13-2016, 11:10 PM
blupupher's Avatar
blupupher
If the topper is level with the top of the cab, tests have shown that it gives better aerodynamics and can improve gas mileage, but the weight of the topper can reduce mileage, so it is a wash.
A tonneau cover does not really improve mileage vs no tonneau, but if you like it, then go for it, and sell the topper for a few hundred.
I like toppers, but they can be a pain when you want to load something tall or just throw stuff in the bed.
  #38
Old 08-14-2016, 06:46 AM
YoGeorge
YoGeorge is offline
Not gonna argue with you. You are wrong. I've gone to larger diameter tires with a 4.6 and lost mileage.
I will assume you were not driving in the 1970's and early 80's when cars had stupid long gearing for EPA mileage purposes but real life mileage and performance stunk. Even at cruising speeds.
In my world, driving involves acceleration.
George
  #39
Old 08-14-2016, 09:20 AM
guyina4x4
guyina4x4 is offline
guyina4x4 is starting off with a positive reputation.
Originally Posted by peters73 View Post
Hey all,What's the best route for mods for a 2003 4.6 for better fuel mileage? I am thinking about a intake, a catback and whatever else.With the catback, would a 3" single or a 2.5" dual exhaust catback? Should I look at a special muffler or get a complete setup from E-Bay. I thought about going to my local muffler shop and having the job done.With the intake, would a cheapy $40.00 E-Bay intake work or a K&N system?I am driving 80 miles round trip a day and I need to do whatever to save gas. A little extra power would be great too.Thanks,Mark
YOU WILL NEVER be happy driving 80 miles a day in a 15 mpg truck, at best 17 mpg, if your spending too much $$$ on gas now
there is nothing you can do to improve the mileage enough to matter to your wallet
my son has an 03 screw, he recently bought a 06 Mazda 3, it gets 30 mpg
he does most of his long distance driving in the car and
hops in the truck on the weekends
the 30 mpg car will pay for itself in 2 years.
mdr617
3.8 & 4.2L V6
09-15-2018 03:02 PM
UP_There
6.7L Power Stroke Diesel
11-03-2017 06:34 PM
08WhiteLariatF350
6.4L Power Stroke Diesel
05-21-2017 11:27 PM
younggun62369
03-20-2017 02:09 PM
chopsieze
1997-2006 Expedition & Navigator
09-15-2016 01:36 PM
Quick Reply: Stock 4.6 needs mods for better Fuel Mileage
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
