Bracket belt routing question
Old 04-20-2016, 07:14 PM
Montync's Avatar
Montync
Montync is offline
So I am in the process of setting up my rebuilt motor.I am wanting to use my original water pump and crank pulley. The power steering waterpump and crank pulley line up. I want to avoid using the smog/alternator bracket. I bought a low mount alternator bracket, the issue is one grove lines up with all the pulleys on the alternator pulley, the other grove is off on the crank pulley.
Ways to fix:
1). 3 grove alternator pulley (I feel the length would put stress on the alternator bearing as I would be using the outer grove)
2) use the smog/alternator bracket, and deal with the, ugliness.
3.) run the a belt around all 4 pulleys like in the picture (I dont know of the issues I might face (not going to race or rev high rpm) (also there is a belt width mismatch)
what are other opitions?
54Hydro
09-09-2018 07:02 PM
tombogue09
06-11-2012 03:24 AM
79FordBlake
04-19-2011 08:52 AM
LCAM-01XA
09-16-2010 11:52 PM
Handegard
03-23-2009 11:57 PM
Quick Reply: Bracket belt routing question
