eletrical problem
Old Dec 19, 2010 | 01:13 PM
fordsrawesome's Avatar
fordsrawesome
eletrical problem
hey guys just a quick question here I have a 77 f250 and i have noticed that my dash lights and my normal lights all kinda flicker and I put new terminal wires on it the other day but that hasn't seemed to help any ideas?
Old Dec 19, 2010 | 01:15 PM
Unroadworthy's Avatar
Unroadworthy
Are the turn signals slower or faster than normal when blinking? That, along with what you describe indicate a rusted ground. I'd find the grounds, and wirebrush them clean. Particularly the negative cable to the engine block. If nothing else, that will eliminate some of the possibilities.
Old Dec 19, 2010 | 01:25 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Can't remember what year they changed to a solid state voltage regulator. If it's the old style, that is a common occurence with them. Maybe someone knows when they changed.
Old Dec 19, 2010 | 03:08 PM
fordsrawesome
I just changed the ground cables negative and positive with heavy 2 ga wires so Ill have to check the other ground and also that voltage thing
Old Dec 27, 2010 | 09:41 AM
bossdog70's Avatar
bossdog70
Electrical problems
I just solved that same problem with my 77 f-100. After checking or replacing many items,and cleaning grounds. It ended up with a lose connection on the taillight,everything works fine now.
Old Jan 1, 2011 | 08:59 AM
fordsrawesome
dadgum guess ill have to start checking things ya it even make my lights dimmer
Old Jan 1, 2011 | 10:20 AM
78 PEB's Avatar
78 PEB
I had somewhat the same issues. I cured it by installing some extra ground wires. I ran one from the engine block to the frame and one from the frame to the cab sheet metal. I used a good heavy one (same size as the battery cables) for the one from the block to the frame and a 12ga. from the frame to the cab. It cured my gremlins. After 30+ years everything gets kinda rusty on these old trucks and the extra grounding did the trick. I have thought about running a 12ga. from the frame to the bed as well but havent done it yet.
2004f250superduty
Nov 4, 2013 11:40 AM
carolinaborn82
2004 - 2008 F150
Jun 25, 2012 11:17 PM
Evan_P
Apr 19, 2012 11:43 PM
Whiteknuckler
Sep 17, 2011 01:06 AM
SoKenfused
1997 - 2003 F150
Mar 1, 2007 11:27 AM
