Tate's 72 Highboy Restoration.
#76
#77
Nice project. Mine has been a lot longer and started as a 2WD F250 in 2004. I drive it more than i work on it. Mostly because it is my truck for anything I need a truck for. I have left my truck pretty much stock and just improving it mechanically. The only thing I have left is the bed restoration. Most of my major projects like cab have been done by retoring a donor part and then swapping it onto the chassis. Don't feel bad about the two year project time, that is still pretty good.
#78
It's Finished
I started in August 2010 on the restoration of this truck and December 16 2012, it is now completed, I will post a summery of the process in a few days. I included just a few pictures made inside the shop because it pouring rain here, when the sun comes back I will make pictures that will show it in a better light. Thanks to everyone who has followed this post and for all your comments, I appreciate it.
#80
Hey tp just wandering did u use a paint gun on the bottom of the cab and firewall. Just curious how that worked out if u never took the cab off. And if you could explain the steps you took in a basic way, paint wise please that'd be great. I've talked to you before about the c6 in a highboy and I'm just assuring that if I buy a c6 out of a 1976 f250 4x4 it will work just the crossmembers and tail shaft. Thanks a lot
#81
The short answer is we sandblasted, cleaned, primed, sprayed Rapture-Liner.
Here is a link to what I used on Amazon
#84
#85
beautiful color combo! The pale blue and white looks great on this era truck, and those bucket seats make it stand out! I cant remember the last time i saw a highboy with those tiny side mirrors, but i prefer the mirrors you replaced them with. All in all, one of the best looking Highboys ive seen in a long time!
#87
Rim's
Absolutely obsessed and impressed with this build beautiful finished product. I'm doing my 69 and it will have the same color's. Your truck rims.. I really like the look on the truck do you remember what brand and style they are? Because I'm looking for something very similar for mine.
#88
Best I can remember they are American Racing wheels, look up AR172 Baja, 16X8, Hope this helps
#89
Beautiful truck. Love the steering wheel.
By the way, could you post a photo of where you drilled the frame for the filler tube. I can't figure out where you put it. I have a 71 F250 4x4 and it looks to me like the tube would go right where the overload spring bracket is on the side of the frame.
Please help, thanks!
#90
Hello, great post. Reading it and very helpful. I'm just starting my 1972 Highboy project. Check out my post and appreciate any tips.
https://www.ford-trucks.com/forums/1...-progress.html
Does your truck look the same? Thanks -
