Exhaust backpressure: How much is too much? - Page 2 - Ford Truck Enthusiasts Forums
Old 12-18-2010, 10:32 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Well, it's the same basics as your '95 with the difference being an electric fuel pump.
Old 12-18-2010, 10:53 AM
plgebbia's Avatar
plgebbia plgebbia is offline
plgebbia has a good reputation on FTE.plgebbia has a good reputation on FTE.
So, what kind of issues would come to mind that cause low power and a chip has no influence on?
Old 12-18-2010, 12:11 PM
bulla's Avatar
bulla bulla is offline
bulla has a very good reputation on FTE.bulla has a very good reputation on FTE.bulla has a very good reputation on FTE.
Figure out if you have a bad ebp sensor and go from there. We know it's limited to the effects it has on performance but if it is really reading that high there is definately a prob on the exaust side.
Old 12-18-2010, 12:32 PM
Quote:
Along the same lines as bulla's thinking, I would be checking the exhaust back pressure valve to make sure that it's fully open.
Does this particular truck have a catalytic converter on it? Some do some don't and it might be clogged.
Old 12-18-2010, 10:30 PM
plgebbia's Avatar
It was a bad sensor, put in a different one and it is 14-26 psi now. there is deffinately a power issue though. The customer picked it up today, but will be bringing it back aroun the first of the year for me to find the power issue.
I will start a specific thread for that.
Thanks for the help guys!
Old 12-18-2010, 10:37 PM
bulla's Avatar
Thanks for the info. We'll see what we can do when you post back.
Old 09-12-2017, 09:39 AM
Pistol7.3 Pistol7.3 is offline
Pistol7.3 is starting off with a positive reputation.
sub'd, Im having similar issues
Old 09-13-2017, 02:37 PM
aawlberninf350's Avatar
aawlberninf350 aawlberninf350 is offline
It's a Van Gogh
aawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud of
7 year old thread bro, not too many more replies coming.
Go ahead and start a new thread so we can give your drivability issue our undivided attention.
P0470 code and EBP readings (overboost?) FL SuperDuty 6.0L Power Stroke Diesel 21 10-31-2017 04:14 PM
Error codes - P0674, P0475, P0381 - how to fix - munireusa Excursion - King of SUVs 4 08-03-2017 01:18 AM
2004 6.0 Possible FICM issue bamajosh 6.0L Power Stroke Diesel 9 01-11-2017 04:06 PM
EBP Sensor Issues comtb 1999 - 2003 7.3L Power Stroke Diesel 3 12-31-2016 03:59 PM
Backfire after modifications dcc73 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-09-2016 03:35 PM
Tags
2007, 350, 73, 95, back, backpressure, diesel, ebpv, exaust, exhaust, f150, f550, ford, normal, powerstroke, pressure, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
