Mustang computer swap ?s
I'm doing the research to swap my 94 maf, E4OD computer out for a 89-93 Mustang maf manual trans computer..
Here Is the ? I have...
#44 on the pickup is HEGO, the Mustang has two, a L and a R HEGO, do I just tie the L and R HEGO #43 and #29 together? and what about the #44 and #49(the HEGO GNDs)?
On the 94, pin 18 and 19 is Data + and Data - I can't find them on the Mustang pinout, so do i just eliminate them? I think yes, but not sure..
Also, Do I need to wire in a BARO? for pin #45?
If so, what are the other two wires? Like, where to I hook them up?
on
Ignore these.
The spreadsheet below outlines the changes necessary to use a Mustang EEC in a truck.
Yes.
Ignore these.
Pin 19 becomes the fuel pump monitor so the wires currently attached there have to go.
No, the truck MAP sensor becomes a Baro when you disconnect the vacuum line, no wiring changes necessary.
Ignore these.
BigLar
on
If you want MAF without the added expense and complication of either buying a dedicated trans controller or swaping in a non-computer controlled trans.. then yes you are limited to one of the truck E4OD EEC's.
It was originally a MAF 5.0, E4OD, I swapped in a 5.8, ZF 5 speed. Add the mods(egr/smog delete) I've done, a Mustang ECU is the only way to keep the CEL from coming on. Plus you have any idea how many tranny codes come up when there isn't a tranny there for the computer to read?!
on
on
I can tell you the second O2 isn't necessary, converted my truck to dual sensors this past summer as an experiment and it made no difference at all. Keep in mind I have a wideband O2 sensor and a tuner system that allows me to watch what the computer is doing in real time so I have data to back this up.
menesesjesse
23
11-07-2012 10:57 PM
