clunk when turning sharp left in 4 wheel high
My 2006 isn't too bad for staying partially engaged after turning off, but growing up ALL of my late 80's - early 90's Ford's
had to backed up a few feet after disengagement
Thanks this helped me
I just locked my hubs in auto on my 06 and this same sound just came back. Didn't understand why. Thanks for the help.
Thats actually incorrect. Each axle (front and rear) has a differential which allows for slippage of each wheel. Meaning on each axle (unless it has a locker) one tire is able to travel slower/faster than the other without binding the drivetrain. The binding you feel when in 4 on dry pavement is actually the binding between the front and rear. If both front tires were "locked" then you would get that binding any time the hubs were locked, regardless of if it's in 4 or not.
Also I think the clunk sound is probably more of a heavy clicking than a clunk. Am I right handyman? What is going on is when the wheel is turned at it's max and the hubs are locked the u-joints are starting to bind causing a clicking sound. It's just another flaw in Fords design. This will happen anytime the hubs are locked, 4 engaged or not.
Worn u-joints? Ever grease them? Even when in 2 wheel drive with the hubs locked and front wheels turned to the max it is very possible you will hear a slight clunking....this is normal u-joint operation. Turning the wheels to the max puts more stress on the operating angle of the u joints. My u joints are brand new in the front axle...replaced them this summer when I did ball joints, when i lock the hubs and turn front wheels to the maximum, i here a slight clunking from the u joints turning at such an angle....it's just normal u joint operation.
bassmas5
1997-2006 Expedition & Navigator
13
08-14-2017 05:42 AM
ad2435
2015 + Expedition & Navigator
05-03-2016 02:51 PM
