99 7.3 won't run
Old Dec 15, 2010 | 08:39 PM
kegbelly's Avatar
kegbelly
99 7.3 won't run
The code it showed was a a ICP code so after research on here and numerous mechaincs I changed the ICP sensor and the cam sensor and it still will not crank and run it turns over great it is almost like it is not getting fuel but there is fuel in the bowl. The pump seems to be working. I am about to pull the trigger and take to the dealer but before I do I would like to here your thoughts on the problem. Thanks
Old Dec 15, 2010 | 09:16 PM
powerstroke72's Avatar
powerstroke72
Moved to 1999 - 2003 7.3L Power Stroke Diesel forum.
Old Dec 16, 2010 | 02:56 AM
Sheldon Plankton's Avatar
Sheldon Plankton
Do you get a wait to start light when you turn on the key?
Old Dec 16, 2010 | 03:48 AM
Muktown's Avatar
Muktown
If you do get a wait to start light and there is still no smoke out the tailpipe the next thing id do is pull the ipr and look at the orings
Old Dec 16, 2010 | 06:31 AM
kegbelly's Avatar
kegbelly
Yes I get the light
Old Dec 16, 2010 | 07:58 AM
Smokin''s Avatar
Smokin'
Smokin
So...it turns over but won't actually start..was it driving fine and then wouldn't restart after sitting, or did it suddenly quit? What's the story behind the no start?
Did you go through the starting system checklist...batteries, GPR, glow plugs, cables?
Old Dec 16, 2010 | 06:04 PM
kegbelly's Avatar
kegbelly
lost power in acceleration on the drive way and died it crank back and ran about 45 seconds and died. Yes new batts and alternator less than 2 weeks old it has plenty of juice and the plugs and injectors are less than a year old. I thought for a sec how it might be the fuel pump but it seems to be pumping fuel in the bowl just as it always hasI know it need like 60lbs of pressure to from the pump to the bowl.
Old Dec 16, 2010 | 06:23 PM
F350-6's Avatar
F350-6
What was the code? P1211 or P1280? Seems like Lisa had ICP codes from a faulty IPR.
Check the IPR to see if the tin nut fell off the back or if the wiring to the IPR is chaffed or corroded.
Old Dec 16, 2010 | 07:31 PM
kegbelly's Avatar
kegbelly
I will check it tomorrow guys thanks so much for the info anything not to carry it to the dealer.
Powerstoke73
Nov 9, 2014 01:19 PM
dclack
Sep 20, 2012 09:51 AM
carrcreekcaller
Jan 16, 2012 05:13 PM
embry1123
Mar 22, 2010 09:13 PM
IceboxFX
16
Mar 18, 2008 07:27 PM
