Long shot
That's just like mine. I recall someone on this board had their seat frame replaced from a similar issue. Also, if it helps, if I pull up the back-front seat adjuster lever, the noise goes away as well. I no longer have warranty and definitely don't want to pay for a fix.
Maybe you could try searching for the other person's seat rattling noise. I'm on a mobile connection and can't help with that.
The plastic on the seat belt clip does rattle on the pillar if not posistioned correcty. But, there is a rattle under the seat. It has to do with the springs and lever that moves the seat forward and backwards. I had to look under with a light and hit the seat with my hand until I found the noise, then greased up or put felt stickers on the area that was causing that. Took 20 minutes.
give it a try
