Tire size change question/recomendation
My 2005 XLT came with bizaar 18 inch tires. Specifically 275/65/18. My 18 inch choices are limited, expensive and most tire dealers argu with me, that my Ford Truck didn't come with 18 inch tires. I am considering a long term cheaper alternative by going to a 17 inch tire with new wheels. My problem is finding a 17 inch tire that will keep my truck the same height and not mess with my speedometer too much. I would appreciate an recomendations or feedback. Thanks.
Your 18"s are not that uncommon. A lot of the trucks came with them actually. Tire dealers arguing with you seems absurd.
Try out this calculator. It's very helpful in comparing a variety of tire sizes and wheel sizes against what you currently have:
Tire Size Calculator - tire & wheel plus sizing
If you think about the cost comparison, you're better off finding new 18" tires, than buying 4 new 17" wheels and new 17" tires.
I figure that buying 17's now long term will be the best way to go. At least where I live, the difference between 17" and 18" aside from the low choices is about $40-$90 more a tire. I tried to get the exact same tires I have on my truck, Wranglers, problem is they do not make them anymore in my size (according the Evans Tires). They suggest Falkens, which I personally wouldn't wish on a Chevy owner, so I am not putting them on my truck.
You may want to check out Tire Rack - Your performance experts for tires and wheels or Discount Tire, Custom Wheels, Truck & Car Rims | Discount Tire. You'll be able to put in a size that you're after, and see all the available choices in that size.
It also sounds like you need to find another tire shop. They are probably a dealer for certain brands, and are not happy going outside of the box. That's what I love about the shop I go to, they aren't a dealer, just a 4WD shop that does great work. They can get me almost anything.
I had a tire dealer tell me the same thing about my stock 17's... that only Ford uses them and he could not get the tire I wanted in that size, and yet it is funny that I called two other dealers and they were able to get them and said that it is not uncommon, and Ford is pretty much the only one who uses that particular size, but are readily available! Depends on the dealer and how hard they want to work I guess! Or what they want to stock and sell. I would go to a different tire dealer!
Greeting from the "Great snowy north"!
I just completed a search for my '04 F150 4x4. LT275 65 18 C load range was the stock rubber. I upsized slightly to LT 275 70 18 in an E load range Several tire choices are available; Goodyear, BFG, General , Toyo, Falken, Nitto to name a few. Check around. It sounds like your shop is not being totally up front with you! Unless you live way south, don't tow or carry a load, experience no Snow or ice and never travel off pavement, a passenger rated tire is very light for a pickup. A load range C, D or E should give you better service and wear. It is not unreasonable to spend $200 to 300 a tire for good rubber here in Western Canada. Check out the "Tire rack " site. Lots of good info and reviews there!
Good luck on your hunt!
