Anyone have a suggestion on the shaky 45mph post i made? I dont know if it still does it after the reflash but ill try it today
I've got 37 Hancooks on mine and it does the wheel wobble around 35-45 mph to. Took into shop and they found the Sway control arm is loose. has alot of play in steering before it turns the tires
You do NOT need Seafoam that much!! Quit using that unless you start having "ignition miss" problems. Go to 5W40 oil and use White bottle of Power Service (Avail at Wal Mart) with every fill up in winter. Use the Gray bottle in summer.
