Stock Restoration Question: Underseat Toolbox - Ford Truck Enthusiasts Forums
Old 12-14-2010, 08:00 AM
jvmcc's Avatar
jvmcc jvmcc is offline
jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.
I have heard that back when they were new, 1953 F-100's had a shallow metal box welded to the floor under the seat. This was where the jack and tire iron were stored. All that's left of this in my old truck are small scraps of sheet metal at the weld points. Does anyone know more about this box? Size? Did it had a lid? I am pretty sure that the truck carried a bumper jack, so I assume that it must have been at least thirty inches long. A photo would be a great help.
Old 12-14-2010, 09:21 AM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
I just went through the Chassis Manual and don't find it. Not in the Accessories section either. Could it have been a dealer item? Stu
Old 12-14-2010, 10:52 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
I've never seen a special box there as a factory item. AFAIK the tools were in a cloth bag. Panels had an open metal box for the tool bag mounted to the wall behind the seat. Trucks came with a frame screw jack, not a bumper jack.
Old 12-14-2010, 10:54 AM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant future
I believe that the "small scraps of sheet metal at the weld points" to which you refer are probably the remnants of the strip of angle metal that was put across the floor at the rear of the seat to keep stuff from behind the seat from moving forward. The only tool-related option that I know of is the tool tray that mounted to/on the rear cab brace behind the seat.
Old 12-14-2010, 05:54 PM
jvmcc's Avatar
I don't know where I got the idea that there was a tool box. Maybe I saw a photo somewhere a long ago. Anyway, something was spot welded to the floor toward the back under the seat. Would it have been simply an "L" shaped piece of sheetmetal, just high enough to keep the jack and tire iron in place? I don't see any spot welds on the sides, so I guess the seat track/frame kept the jack in place sideways. Does anyone have this original piece of metal still in place in their truck?
Old 12-14-2010, 06:13 PM
Harrier's Avatar
Harrier Harrier is offline
Harrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant future
I just ran out and took a couple of pictures of the metal piece in my 55 F250.
It is 41 inches long and 2 inches high.
Is that what you are needing?
Old 12-14-2010, 06:14 PM
Harrier's Avatar
Here is a picture with the seat brackets still in.
Old 12-14-2010, 06:32 PM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
According to the sales brochures, the "Tool Kit" was a canvas bag that included the following items:
1. Pliars;
2. Screw Driver;
3. Tire Iron;
4. Spark Plug and Cylinder Head Bolt Wrench
5. Wheel Stud Nut Wrench; and,
5. Jack Handle
This along with a 1 1/2 ton Mechanical Jack was standard equipment.
On the 48-50 (?) 51/52 Series there was a tool tray atop the gas tank behind the seat. That is not listed as being either standard or optional equipment.
Starting in 53 the tools were stored under the seat as far as discussions here have shown - perhaps behind the lip you pictured.
Old 12-14-2010, 07:15 PM
CharlieLed's Avatar
Those strips are a PITA...most people either cut them out or just bend them over. Once you have your carpet and pad installed you'll never know it's there.
Old 12-14-2010, 08:20 PM
abe's Avatar
abe abe is online now
abe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant future
Quote:
1. Pliars;
2. Screw Driver;
3. Tire Iron;
5. Jack Handle
Hi Julie,
I know we discussed this before. This is the first time I saw a list of tools that came with the 53-56 pickups. I have a jack (several) and jack handle (several). I have a funny looking wrench that was in my truck when I bought it from my grandfather. It doesn;t say FORD on it however. Do you know more about these 6 tools. Where did you see this list. I have a lot of literature so I can learn more of this stuff but have not found that yet. Perhaps I have come across this stuff but did not know it....
please inform,
thanks, Abe
Old 12-14-2010, 08:44 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant future
You're probably thinking of the tool box that Jules mentioned for the 48-52 trucks. It wasn't under the seat though, it was upon top of the fuel tank. The 48-50 trucks box had rounded ends and the 51/52 trucks were squared off.
Not sure what if any the 53-56 trucks might have had. I know the 59 and 60 trucks that I've had didn't have anything (or should I say....anything left..LOL)
Bobby
Old 12-15-2010, 09:11 AM
jvmcc's Avatar
Thanks all, especially to Harrier and Julie. This is the information that I was hoping to find. Very helpful. I'm hoping to have my whole truck ready for paint by mid summer (2011). I'll post pics if I actually get that far.
Old 12-15-2010, 09:42 AM
GLR's Avatar
GLR GLR is offline
Posting Legend
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
I just check my 1948-1956 Ford Truck Parts and Accessories Illustrations Catalog. Nothing indicated for a tool box under the seat. That strip is shown in several places as part of the floor. Pics do show seat belt installation which is kind of neat for a 53.
Welding in Wrap Around window 58 F100 jenkinsj Paint & Bodywork 4 05-04-2014 09:44 PM
Stock truck question... tire jack storage jvmcc 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 08-26-2013 07:43 PM
space saver for guys with stacks jg96powerstroker 1994.5 - 1997 7.3L Power Stroke Diesel 10 07-10-2011 09:20 AM
Rotating Tires - Lifting/Holding Points? Torky2 Escape & Escape Hybrid 6 03-31-2011 10:17 AM
Need a good and tall Jack for the X hummer5 Excursion - King of SUVs 18 01-04-2011 10:49 PM
Tags
1948, 1956, 2007, box, f1, f150, f250, ford, seat, stock, tool, toolbox, tray, truck, underseat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
