Water Pump Differences
Old Mar 3, 2003 | 11:32 AM
hartmark's Avatar
hartmark
Anyone out there know what is the difference between GMB's regular and high performance water pumps? I want to see if the difference is really worth $30. It looks like the current water pump is original (as it should be with 30K miles), and the shaft wobbles when it runs (though it doesn't leak yet). I want to replace it before there's any real problem (or catastrophic failure).
I haven't had any major cooling problems but the gauge reads a little high. I'll probably add a mechanical gauge to see if it is truly high.
Thanks,
Mark
Old Mar 8, 2003 | 01:50 AM
dinosaurfan's Avatar
dinosaurfan
Mark, who is GMB ? Usually the pump to get is the one intended for an air conditioned truck. Some of the pumps have a bigger impellor than others, but I think you get the big one if you ask for the A/C model. And how warm is the engine now ? A mechanical gauge would be a good idea. You want to run at about 205-215*. Don't fall for the myth that a 'cooler running engine' is a good thing. DF
Old Mar 8, 2003 | 08:08 AM
hartmark's Avatar
hartmark
GMB is just an aftermarket waterpump maker. They have a "high performance" pump that sells at Advance for less than $70. Someday I might shell out for the aluminum edelbrock pump, but for now I think the regular pump will meet my needs fine. The parts places seem to list the same pump for AC and non-AC applications.
I think I just need to get a decent set of gauges. My dash is mostly idiot lights so it isn't much use. Of course the temp gauge is not calibrated (just T E M P) so I really don't have a good idea where it is running.
Thanks for your comments.
Mark
Old Mar 8, 2003 | 12:13 PM
karljay's Avatar
karljay
I read in one of the performance books that there are two pumps, and only the very early ones where 'low' flow types and all the newer (mid/late 60's on) were high flow.
The A/C trucks use a different pully system, this causes the pump to spin faster. I converted a 73 F250 from non AC to AC and got all the pullies from an AC truck and they are different sizes.
I ended up getting the Edelbrock Alum pump, but if you want more flow you can get the AC pullies and/or get a backing plate from www.jegs.com for about $10 that it welded to the back of the stock impeller inside the pump.
9000_red
Nov 17, 2015 03:16 PM
Dan_Johnston
Oct 31, 2015 09:12 AM
CXA152
33
Apr 25, 2012 11:08 PM
Bubba Jones
1978 - 1996 Big Bronco
Apr 18, 2008 10:17 AM
eds94aero
Aerostar
18
Feb 12, 2005 12:13 PM
