Wire diagram for brake lights. Want a blackout switch. - Ford Truck Enthusiasts Forums
Old 12-12-2010, 01:06 PM
FreeDevin's Avatar
FreeDevin FreeDevin is offline
FreeDevin is starting off with a positive reputation.
Hey guys, I want to get a pair of night vision goggles and already have infrared lights installed on the truck. What I need to do next is install a toggle switch for killing the brake lights, so I can run the truck blacked-out and put on the brakes without the truck giving itself away by the brakes lighting up. Any ideas?
Old 12-12-2010, 03:11 PM
firemaster's Avatar
firemaster firemaster is offline
firemaster is gaining momentum as a positive member of FTE.
Got some pretty covert operation goin on there...I don't dare ask why you need this setup. I would think you'd have to put a switch somewhere between the brake pedal switch. Although I am wondering.....I would think that whomever or whatever your trying to sneak up on would hear the diesel engine.
Old 12-12-2010, 03:33 PM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
Maybe this will help.
Old 12-12-2010, 03:36 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
Rushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud of
Quote:
good point
Old 12-12-2010, 03:38 PM
woodnthings's Avatar
woodnthings woodnthings is offline
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
This should be what you are looking for. Like firemaster said, the brake pedal switch wiring would be your best bet. (Page 90-4)
2002 Exterior Lights Diagram
Old 12-12-2010, 03:48 PM
rbsample's Avatar
rbsample rbsample is offline
rbsample is starting off with a positive reputation.
Not that it matters but in the great state of PA that switch would be illegal. It has to do with the vehicle code and the police thinking if you are trying to kill your brake lights you must be up to no good
Old 12-12-2010, 04:02 PM
SLAMMIN 22 SLAMMIN 22 is offline
SLAMMIN 22 is starting off with a positive reputation.
Like this.....LOL your on the right track start at the brake pedal switch ran one on my semi when I had it makes the popo's think you are slowing down when you really dont .Thats what i used mine for anyway good luck
Old 12-12-2010, 04:05 PM
FreeDevin's Avatar
Quote:
Originally Posted by Rushmore X View Post
good point
Actually, yall would be surprised.
I don't intend to do anything illegal. I have had night vision goggles before and used them to help me see better at night on my boat, camping, etc.
For the same reason I have a lift, I don't intend to do anything bad with it, just another cool toy that's nice to have but not necessary to have.
Thanks for diagram! I'll check it out!
Old 12-12-2010, 04:15 PM
driximus's Avatar
driximus driximus is offline
driximus is gaining momentum as a positive member of FTE.driximus is gaining momentum as a positive member of FTE.
I hope you dont plan on driving around with NVG's. It hard enough to just walk around in them. and most have zero depth perception.
Old 12-12-2010, 11:01 PM
Rushmore X's Avatar
In my younger days I might have done something illegal with them... then again it's illegal to do that here too...
Old 12-13-2010, 01:32 AM
FreeDevin's Avatar
The diagrams were super helpful! The green wire coming from the brake pedal position switch is the correct one.
1988 brake light problem wrd0225 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 05-04-2016 04:49 PM
1968 Ford F250 Brake light switch Coorslight3322 1967 - 1972 F-100 & Larger F-Series Trucks 1 04-16-2016 12:19 AM
No Brake Lights or trailer brake. ds086121 1999 to 2016 Super Duty 5 03-03-2010 12:06 AM
Brake Light Switch Help Needed Brainard 66 1961 - 1966 F-100 & Larger F-Series Trucks 14 05-19-2009 12:20 PM
brake light switch f100tough 1961 - 1966 F-100 & Larger F-Series Trucks 24 11-29-2004 03:21 PM
Tags
96, black, blackout, brake, brakelights, brakes, diagram, f250, ford, install, kill, lights, switch, truck, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
