EGR Upgrade 6.0
EGR Upgrade 6.0
Hi all,
I have a 2009 6.0 E350 just purchased from Ryder. I have read about and seen the horrors on TV about the EGR failures. Dose anyone know if my truck is one of those affected or has Ford fixed the issue by the time mine was built? The mileage is 158K.
Thanks,
Cryobossman:
Thanks,
Cryobossman:
Last edited by Cryobossman; 12-21-2012 at 09:00 AM. Reason: Forgot to mention the mileage.
That isn't really true from what I know. The earlier round EGR coolers had a better record then the later square ones. You most likely have the newer square one.
If you keep track of the ECT and EOT and replace the oil cooler before the temp difference exceeds 15 degrees the factory EGR cooler may last a long time.
If you don't keep track, or the temp difference starts to exceed 15 degrees while riding down the road at 65 mph you are most likely going to have an EGR cooler failure. When you get here you will need a new oil cooler and an EGR cooler/ EGR delete kit.
If you are going to repace the oil cooler get one from Bullet Proof Diesel.
Hope this helps.
Hope this helps.
EOT = Engine Oil Temperature
The delta, or difference between the two temperatures should be no more than 15 degrees when the van is operated at normal highway speeds and level road.
You can monitor both with something such as a ScanGauge II, available online and at places like Advance Auto and Auto Zone.
The 6.0 is slightly detuned in the E-series vans, so they don't experience some of the extremes that pickup owners experience. But EGR cooler failures are not unheard of in the vans. Getting to the oil cooler and EGR cooler involves taking out the turbo and other parts. The big cost is labor, not parts.
EGR Upgrade 6.0
Thanks guys, I will look into your recommendations. As for the type of driving I will be doing mostly will be local but occasionally going from Lexington, Ky. to Newark, Delaware through the mountains of Wv. and Maryland. Would it make sense to monitor the two temps and if they are getting far apart to slow down or stop for a while to cool down? or is it too late by then?
Dick
Dick
Remember that the 15 degree delta is at speed on level road 65 mph no wind or temp extremes.
When you hit those long uphill grades and mountain passes that the engine may or will not maintain that 15 degree difference.
Keep your EOT under 230 degrees and the ECT below 220 - you can do that by keeping engine rpm at or under 2200 rpm which means that you will have to slow down on those hills.
If you see it going above those temps you might want to pull over and take a short break.
Of course there are those 6.0 owners that will tell you that you can exceed these numbers and that they have done so without harm to the engine. Don't do that.
Does the tsb recommend any particular dry lake test bed for running at wide open throttle?
Elsewhere on this somewhat informative forum you should read:
Recommended Reading
I think it answers some of the OP questions and more.
EGR Upgrade 6.0
Wow, lots of different thoughts! I appreciate all of your input and am somewhat confused but will take all into consideration. I wonder if I did the right thing by buying this rig!
Seems like no one likes to work on the vans! Can't blame them for that I guess but there are a lot of them out there. Maybe that's why Ford stopped offering the diesel in them.
I just ordered the Scangauge II from Amazon so we will see what happens when I get it in and working.
Merry Christmas to you all! I will keep posting.
Thanks,
Dick
Thanks,
Dick
Quite hilarious! Love it!
Recommended Reading
Recommended Reading
The older TSB referenced holding 65mph for a certain distance (6 miles?) and the temp difference should be no more than 25 degrees. Then the newer TSB came out and referenced the above 15 degree at WOT.
FWIW I see 0-2 putzing around town. 2-4 45-55 mph, around 6 @ 65mph and 6-9 at a steady 75-80 mph.
Josh
Thanks,
Dick
Thanks,
Dick
The E-series replacement, the Ford Transit, will have diesel power as an option.
