a little search help? tailshaft seal? doghouse removal?
Old 12-10-2010, 06:25 PM
r_reed's Avatar
r_reed
r_reed is offline
r_reed is a splendid one to beholdr_reed is a splendid one to beholdr_reed is a splendid one to beholdr_reed is a splendid one to beholdr_reed is a splendid one to beholdr_reed is a splendid one to behold
i've done a diligent search and can not find a thread (i know i've seen several) on the bolts to remove the doghouse on a '49 f1. i'm also wondering if there is a rear removable seal on the tailshaft of the transmission. getting ready to put the driveshaft back in (ford 9" with 3.50 gears in, woo hoo) and move on to make the truck look pretty. thanks, dick r.
Old 12-10-2010, 06:42 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
By "doghouse" do you mean the floor plate over the trans? It's just a bejillion sheet metal screws.
Yes, there is a replaceable seal on the tailhousing. P/N 21C-7052-A
NAPA carries it, as I recall.
Edit: nope, NAPA doesn't show it, Dennis C does
http://www.parts123.com/parts123/yb....Z5Z5Z50000024C
The seal dimensions are: 2.378" OD, 1/2" ID - 3/4" deep according to the Parts CD, but that ID doesn't seem right. I bet it should be 1-1/2", measure your driveshaft. Someone can match yours if it has a National Seal or Chicago Rawhide (CR) number on it.
Old 12-10-2010, 08:09 PM
r_reed's Avatar
r_reed
r_reed is offline
thanks ross, as always. oops, i meant front fenders/valence, etc. thought that was called doghouse. also failed to mention i have the HD 3 speed, don't know if that makes a diff. thanks again. dick r.
Old 12-10-2010, 08:42 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Doghouse typically refers to an inside engine cover, like found on a van or cabover truck. Your front fender, etc., assembly would be the nose or front clip. (not to be confused with the term as used by front frame/suspension swappers)
The front clip comes off by removing the bolts at the runningboard to fender, two at the rear edge of the inner fender apron, one at the top to the cowl, one at the bottom to the frame, (on a 52, the lower bolt also attaches to cowl, not to frame) and the three on each side under the fender through the apron to the radiator support. Thee's a few wires to unplug, as well, but that's all that holds the front end on.
Old 12-10-2010, 08:55 PM
r_reed's Avatar
r_reed
r_reed is offline
lessons learned. no wonder my search wasn't working out. thanks guys. i'd be lost without FTE. happy holidays.
57t-bird
Aerostar
02-06-2014 08:59 PM
lavatan
03-09-2012 08:26 PM
83Van
09-30-2005 08:39 PM
scientia
1968-2013 Full Size Vans
02-27-2004 06:52 PM
dogtoy25
1997 - 2003 F150
12-03-2002 10:57 PM
Quick Reply: a little search help? tailshaft seal? doghouse removal?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
