codes
Old Dec 10, 2010 | 03:15 PM
1991ford_trucker's Avatar
1991ford_trucker
codes
I tested my truck with a scanner and got the codes 174 and 334. What do they mean and what do I need to do to fix it. Thanks
Old Dec 10, 2010 | 03:42 PM
danr1's Avatar
danr1
174 suggest the O2 sensor is dieing or just dirty.
334 suggests the egr valve is stuck part way open.
Old Dec 10, 2010 | 03:44 PM
1991ford_trucker
So replace both?
Old Dec 10, 2010 | 03:59 PM
danr1's Avatar
danr1
Originally Posted by 1991ford_trucker
So replace both?
No not necessarily, first a little testing be in order.
If you have no idea how old the O2 sensor is or know its been in there on the plus side of 50-60k then yea just replace it.
The egr valve same thing, do some tests it before replacing it. They are part of the emissions system and are built tough to last.
The valve might be fine but the EVP might be faulty for example.
It should read slightly less but no greater then 5000ohm's fully closed, show a steady even drop to 100ohm fully open, (Fully open = 10inches-HG applied at the EGR valve).
Old Dec 10, 2010 | 04:07 PM
jroehl's Avatar
jroehl
If your truck is a '91, you have 2-digit codes.
Jason
Old Dec 10, 2010 | 04:09 PM
1991ford_trucker
They came out 3 digit
Old Dec 10, 2010 | 04:29 PM
danr1's Avatar
danr1
jroehl is correct, if your asking about the model year truck your user ID is based on then yea it'd throw 2 digit codes not three.
Old Dec 10, 2010 | 05:15 PM
1991ford_trucker
Its a 91. It says 06/91 on the tag on the cab. And i got 3 digit numbers
Old Dec 10, 2010 | 06:02 PM
jroehl's Avatar
jroehl
How did you read the codes?
Jason
Old Dec 10, 2010 | 06:12 PM
1991ford_trucker
a code scanner
Old Dec 10, 2010 | 06:14 PM
danr1's Avatar
danr1
Do you know if someone changed the computer?
Old Dec 10, 2010 | 06:15 PM
jroehl's Avatar
jroehl
Try this instead:
Ford Fuel Injection » How To Run a Self-Test
Jason
Old Dec 10, 2010 | 06:17 PM
court1100f's Avatar
court1100f
guys who cares what year it is. hes not asking if those are the codes it gave hes making a statement and wanting feedback based on that statement not a debate as to whether or not his truck provided him with the codes he says it did or not. I think HE knows what codes His truck gave.
wouldn't a code puller be more user friendly than the check engine light flashes???? alotta weird stuff gets done with these old trucks so suffice it to say for what ever reason his particular computer outputs 3 digit codes
Old Dec 10, 2010 | 06:19 PM
jroehl's Avatar
jroehl
A '91 and older will have two digit codes. Anything else is errant info, and info based on 3-digit codes will just mean he's beating his head against the wall with it.
Jason
Old Dec 10, 2010 | 06:25 PM
danr1's Avatar
danr1
Jason
Exactly, we can't help him if the info given is wrong for any reason, just end up sending em on a wild goose chase.
If for some reason it turns out his truck does throw 3 digit codes so be it however a 91 should give 2 digit codes, we need to work that out first before moving on.
