Ford straight 300 transmission compatibility(zf5 s42)
There are some excellent threads to read here at FTE, if you use the 'search' option. Do a google search too. There is a lot of info out there.
It is also possible to convert the ZF to a manual clutch. There is a thread regarding it.
I don't want to cast a shadow on your hopes, but I'd say that finding a truck in the j.yard with all the needed goodies to do the swap is going to be the proverbial needle in a haystack.
Here is a photo of all you need.
<a href="http://s659.photobucket.com/albums/uu316/bobbyrogue/?action=view&current=auto_to_manual_swap.jpg" target="_blank"><img src="http://i659.photobucket.com/albums/uu316/bobbyrogue/auto_to_manual_swap.jpg" border="0" alt="Photobucket"></a>
do you have the link for the manual clutch conversion for the zf s5-42
Dual shocks in the front was a pretty common option. Both my Broncos have them.
Bought it second hand but I am sure it was HD special order from the factory. Zf's are a good tranny but it had the lighter hydraulic clutch in it in front of it. Just a 1/2 ton truck. I also had an f250 with an AOD and it was a decent tranny. Running a c-6 behind a 300 now and it's a good tranny too.
#30
Don't take this to the bank because it's "if I remember correctly", but some of the diesel ZF trannies used an external slave and could theoretically be converted to manual clutch. The gas versions - and the small block in particular - use a donut-shaped internal slave that fits around the input shaft. I suppose a determined person could fabricate a manual clutch conversion, maybe, but without looking under my truck I'll say it would be far, far easier to mount a clutch master cylinder on your firewall. There's nowhere on the ZF to mount a clutch fork and no opening in the case through which it could protrude.
There are no close or wide ratio ZF's per se, just diesel and gas. Diesels use different gear ratios. The small block ZF5 s42 and s47 are interchangeable on a 300.
