Just wondering what gear ratios came stock in 79 broncos.
My 9" has some sort of a limited slip type locker in it, guessing from the factory?
And it's got a dana 44 up front.
The trac-loc LS was a factory unit. The most common ratio was 3.50:1 with an optional 4.11:1 for certain. There may have been "shorter" ratios available in the F-series at the time.
Is there any way to figure out what ratio without taking the rear chunk out? I've never removed one from a 9" before.. I imagine it's not extremely difficult.
Look at the tag on the driver's door it should have an axle code on it, post up and let us know what you find. My 79 Bronco had 3.50s open diffs ft and rear, now it has 4.88s with a Power Lock in the front and a full spool in the rear.
No axles tags. And the tag that was riveted into the door had these codes that didn't really seem like axle codes. The first row- U15HLED7016. The second row is the VIN- 104H0150AT1GH2. I don't know if that's helpful. And the last row(bottom row) has 06100, 1979 28 on it. Don't know it this is helpful but thanks anyways.
So if it turns three and a half times it'd be 3.55 ratio? Sounds simple enough. I'll probably end up the takin the chunk out anyways. It could use a new gasket.
It is fairly straight forward. Both axles have to come out a bit then take the third member out. It is somewhat heavy. Just have some rags or small pails ready (gear oil) and some RTV siicone and more gear oil.
I figured out from my new bronco graveyard catalog that my running gear has 3.50 gears in it, which I think is alright for the 35's I plan to put on it.
