'08 F250 - low noise when steering or braking at low speeds - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-08-2010, 07:57 AM
rdollie rdollie is offline
rdollie is starting off with a positive reputation.
I mentioned it during my last service visit to the dealer but they couldn't duplicate this one. I have a low noise almost like a whine that I can hear when making sharp turns or braking in a parking lot. There is no vibration I can feel in the steering wheel or brakes though. To my ear the problem is getting a little bit louder.
I'm about to head to the dealer again for a part replacement and thought I'd ask the group here for any advice on what to ask the dealer to check if anybody else has encountered this problem?
Thanks.
Cheers,
Russell
p.s. - I struck out with the search engine (found similar reports from older trucks but no definitive diagnosis.)
Old 12-08-2010, 08:35 AM
DAVE67FD's Avatar
DAVE67FD DAVE67FD is offline
DAVE67FD is gaining momentum as a positive member of FTE.
Try to be more specific.
Does it happen "only" when braking or "only" when making sharp turns or "only" happens when doing both? Is the sound within the cab or is more excessive outside? (with window down for example).
Old 12-08-2010, 08:42 AM
Good questions.
It can happen at times only when braking OR only when steering. However, at times, when it is happening with steering I can brake and the sound gets slightly louder. I've tried it with the window down and really don't hear much of the noise that way. It seems to emanate from the front end and up through the firewall.
Old 12-08-2010, 09:23 AM
STEELHQ STEELHQ is offline
STEELHQ is starting off with a positive reputation.
Quote:
Originally Posted by rdollie View Post
Good questions.
My 2010 f250 makes the same noise its like a humming sound?
Old 12-08-2010, 10:28 AM
Yes, somewhere between hum and low-pitch low-frequency whine.I only noticed it over the past few weeks and the truck has just under 15,000 miles.
Quote:
Old 12-08-2010, 10:31 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
On the PSD, both the brakes (Hydro-boost) and the power steering are boosted by the same thing, the power steering pump.
I would see if your power steering fluid is up to the right level, and if it is, have someone move the steering wheel and apply the brake while you listen with the hood up. The noise is probably coming from the power steering pump, and if so, it might need to be replaced.
It's probably a bypass valve in the pump that's making noise.
Or, somehow, someone put the wrong fluid in the system.
Old 12-08-2010, 11:58 AM
TenHoles's Avatar
TenHoles TenHoles is offline
TenHoles is starting off with a positive reputation.
My V10 has hydroboost as well and it was making a similar noise this summer. Ended up being low on P/S fluid due to the input shaft on the P/S pump was leaking. I just pulled the pump out, pulled the pulley off, replaced the seal and put it all back together. Haven't heard the noise since.
Old 12-08-2010, 12:34 PM
Yes thats the sound i get but my truck only has 4000 miles and its the 5.4 gas.
Old 12-08-2010, 12:53 PM
cut38 cut38 is offline
cut38 is starting off with a positive reputation.
I have an 01 f350 that makes the same noise and its driving me crazy.Mine started when a Ps line ruptured and leaked all the fluid out. I replaced the line and the PS pump and that is when the noise started. I've been living with it for about a year now and any help at fixing this problem would be greatly appreciated. On a side note, the PS fluid level is good and I've talked to a ford mechanic at a local dealer and he seems to think that it's air in the system. I've tried getting the air out of the system but the noise is still there. Also the steering and brakes work fine, its just the irritating noise that I can't get rid of.
Moan from front end at low speed..brakes or hub??? Mystic_Cobra 6.4L Power Stroke Diesel 15 01-20-2017 05:04 AM
Noise in front end elishaman 1999 to 2016 Super Duty 4 04-20-2016 01:30 PM
01 7.3 vib/noise up front jaymoford 1999 - 2003 7.3L Power Stroke Diesel 8 12-23-2015 01:34 PM
Strange noise nobody seems to recognize dieseldrew 2009 - 2014 F150 2 10-21-2015 01:21 AM
Front End Clicking Noise Msp541 Explorer, Sport Trac, Mountaineer & Aviator 14 11-03-2005 09:37 PM
Tags
04, 08, brake, f250, fluid, hum, humming, low, makes, noise, power, recall, slowing, steer, steering, whine
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
