08 F250 starts but has no throttle
I have a 2008 F250 5.4 6 speed standard, the truck starts perfect, no depress the pedal and it does nothing, i tried a code reader and code P2111, P2112, and P2004 came up I tried changing the gas pedal and the throttle body and made no difference had any one had the same issue...i called the local dealer they can't fit me in till Dec.15,2010 i can't wait that long............thank you!!!!!!
Since you've changed the throttle body and the gas pedal the next logical step would be to look for broken wires between the gas pedal and the computer and the computer and the throttle body. Do you have voltage at the gas pedal connector? You'll have to find a schematic or troubleshooting guide to figure out where and what the voltage should be.
I had a similar issue recently; loaded the tuner but pulled the plug before turning the key off. Gravity, cheap and dependable, got me to the bottom of the hill but pressing the accelerator had no effect. Put the tuner back to check for codes, reloaded the tune, and followed the instructions . . . turn key off . . . disconnect tuner.
This may not help the OP but may help someone out there if it ever happens.
Curt
Curt
7.3stroker2
04-17-2023 09:46 AM
75highboy
04-11-2001 02:47 AM
