1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2004 F350 6.0 won't start
Old 12-06-2010, 02:04 PM
Mjohnson1617's Avatar
Mjohnson1617
Mjohnson1617 is offline
I went out one morning after it had snowed and went to start my truck. Put the key in the ignition, waited for the glow plug to warm up, then turned the key. It started to crank and just kept cranking, so I put the key back to on and waited. When I turned the key again, it began to crank and then stopped cranking completely on its own. I checked the batteries, they're both good. I checked the fuses and they're all good. I tested the starter and it's good. The starter gets power from the battery, but when I turn the key the ignition doesn't send power to the starter. If I try to manually crank the starter with the screw driver between the terminals it just cranks but won't catch.
Any ideas?
Old 12-06-2010, 02:12 PM
Fishin76's Avatar
Fishin76
Fishin76 is offline
Manual or Auto? think clutch switch, neutral safety switch, Park/neutral interlock, brake interlock. if any of those are (or aren't) make contact, you may not get power to the starter.
Just a thought.
Old 12-06-2010, 02:43 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Locate your starter relay. Sounds like it's hung up or fried.
Jeff Taylor
1997-2006 Expedition & Navigator
11-02-2015 10:53 AM
OFD2413
07-11-2015 08:53 AM
dan6915
06-11-2015 10:30 AM
shadetree enthusiast
09-18-2014 03:39 PM
Singing River Farm
18
01-25-2014 03:51 PM
Quick Reply: 2004 F350 6.0 won't start
